Author Topic: Jacuzzi / Sundance footwell socks  (Read 3978 times)
bulmer4nc
  • Now a Canes Fan.
« on: April 06, 2005, 12:53:29 pm »
Does anyone know if these are the same size?  Can I just go to my local Jacuzzi dealer and get socks from them for my Optima?
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: Jacuzzi / Sundance footwell socks
« Reply #1 on: April 06, 2005, 01:01:13 pm »
As long as you know the year of the tub, just go to your local dealer.  They shoud stock them.
bulmer4nc
  • Now a Canes Fan.
« Reply #2 on: April 06, 2005, 01:04:21 pm »
You're saying my local Jacuzzi dealer will stock the socks that will fit our 04 Optima?  I assumed they would stock the ones that fit the tubs they sell.  I was just checking if anyone knew if they fit an Optima since they appear to be around the same size from any pictures I've seen.
Lori
« Reply #3 on: April 06, 2005, 02:52:00 pm »
Hey Bulmer,
I'd call and ask!  The worst they can say is no and I'm sure they understand your dealer has gone out of business!
« Reply #4 on: April 06, 2005, 03:27:58 pm »
Just to warn you, there are two different size socks that Sundance uses.
fletch49
« Reply #5 on: April 06, 2005, 05:43:14 pm »
What is the purpose of these socks? If they screen the intake water, is it needed? Is Jacuzzi and Sundance doing something different than the rest of the industry?
johnnythunders
  • Jacuzzi J-355
« Reply #6 on: April 06, 2005, 08:53:56 pm »
I only use these socks when i change the water.They get a bit dirty after that,I find out you get power with them off.Jt :-/
« Reply #7 on: April 06, 2005, 09:28:31 pm »
Those socks keep sand and other debris out of your plumbing.  In particular, in the Optima, there is no filter for the water drawn into the single speed pump.  The water gets drawn into the intakes at the bottom of the footwell, and thru the diverter valve and pump, then out the jets served by that pump.
Sundance says use them, that's good enough for me.
Since Jacuzzi owns Sundance, there may be some common parts between the spas.  The Jacuzzi dealer near my office said they could get me micro filters, pleated filters, socks, etc....  Not sure if Jacuzzi even uses micro filters.
« Last Edit: April 06, 2005, 09:29:39 pm by Brewman »
johnnythunders
  • Jacuzzi J-355
« Reply #8 on: April 07, 2005, 09:59:18 pm »
Should keep them on,,,,,but for some reason it seems that the jets have more power with them off.{maybe its in my head}But they should be on when you change your water and after that i don't think it makes a differance unless you live near a beach.Jt
