Author Topic: cedar skirting advice  (Read 9982 times)
Re: cedar skirting advice
« Reply #15 on: March 29, 2005, 02:40:34 pm »
I use Superdeck tranparent stain once per year with great results so far.  Many manufacturers use (or used) Superdeck stains.  It is a one coat process and easy to apply.
bosco0633
  • Look into my eyes
« Reply #16 on: March 29, 2005, 03:05:26 pm »
i dont know why it got a thumbs down.  It did it automatically when i started the thread.  I dont think that I can change it.
« Reply #17 on: March 30, 2005, 09:51:10 am »
Use a high grade stain and it will last for years. You will need to spend at least $30-40 a gallon for good stain. I use three different kinds depends on how much the customers wants to spend from $10 to $65 a gallon. The higher the oil content the better the stain and price.
Gary is exactly right: using just oil misses the UV inhibitors, stabilizers, pigment (if desired) and other additives which make a good stain, well, a good stain. Most stains are based on oil - it's the additives that make them work better.
I have used 'SuperDeck' since back when it was called "DuckBack" with great results.
