Author Topic: It's good to be princess!!!  (Read 2968 times)
Lori
« on: March 29, 2005, 08:11:00 pm »
 ;D
So, I get a call from the head spa tech!  He made it out to see the tub!  But get this, the leak is no longer there!  I guess being the goddess has some benefit!   ;D ;)
So, the story goes like this...Hubby told me Sunday that he noticed that the area where the leak had been was dry.  I told him that maybe it leaked when I ran the jets.  I got in and had my usual soak.  I didn't notice the leak, but figured it would take a bit of time to work it's way through the foam.  So...it was still dry Monday (I took the day off to take care of some things).
The tech told me that he thought the same thing (jets were causing the leak to appear) but he ran them for around 45 minutes today and still nothing!  So...either the guy fixed it when he came out and it took a bit for the visible signs of the leak to disappear, or the spa fairies came and fixed the leak for me!
Either way, I am one happy Princess of Quite Alot!
I'll let you know if the leakage signs appear again!
Re: It's good to be princess!!!
« Reply #1 on: March 29, 2005, 08:19:41 pm »
LMAO Lori! You scared it away! ;D
I hope it stays that way for ya! Very bizarre!
stuart
« Reply #2 on: March 29, 2005, 08:22:17 pm »
Sooo....if it comes back look at your ozone unit and see if you can feel moisture around the bottom of it.
It's very possible that you had a check valve failing.
Lori
« Reply #3 on: March 30, 2005, 06:51:15 am »
I'll do that Stuart!
Very bizarre indeed!  The tech was a bit perplexed, as well!
Oh well...I won't look a gift-horse in the mouth!
Thanks to all for the encouragment and suggestions!
« Reply #4 on: March 30, 2005, 08:40:37 am »
Maybe it's time for you to start buying lottery tickets big time....................
« Reply #5 on: March 30, 2005, 08:47:17 am »
Yeah, sometimes the flakes of dead skin and wads of hair will clog up a leak and there you go!!
Hmm. I may come back and change that one later.....
You could be experiencing a multi-dimensional warp: aliens love to sneak in and snatch away our water, and a leaking pipe seems to call out to them.
Or -
Your technician tightened the drain cap without even thinking, and that was it: the water was just running under the spa and coming out the other side?
OR -
You are the Princess.
Perk1
  • Relaxed when wet....
« Reply #6 on: March 30, 2005, 09:13:51 am »
Another reason to buy a HotSpring....self sealing leaks....maybe you can have Watkins put that in the next brochure Chas...LOL...
« Reply #7 on: March 30, 2005, 09:17:09 am »
I'm all over it ! ;)
