Author Topic: Question for spa techs/people in the know....  (Read 3765 times)
autoplay
« on: March 29, 2005, 07:05:33 am »
I own a 2003,Caldera Geneva Utopia. It has 3 diverter valves. I want to do some preventive maintenance on the valves.
My question is.....What lubricate can/should I use on the O-rings for the diverter valves? Will the plain old stand by "vaseline" work?
Thx,Rich
autoplay
Re: Question for spa techs/people in the know....
« Reply #1 on: March 29, 2005, 07:14:19 am »
On an unrelated topic.....Doesn't Mork work as a tech/seller of CaVeN spas?  Found the pulled post amusing ;)
« Reply #3 on: March 29, 2005, 09:12:38 am »
Use a teflon-based lube.
Don't use Vaseline.
Gary
« Reply #4 on: March 29, 2005, 10:58:59 am »
Don't use Vaseline.
You would be better of and find Teflon o'rings. Lubing the o'rings will cause debris to gather.
stuart
« Reply #5 on: March 29, 2005, 08:27:23 pm »
There is a lube that you can purchase called "Magic Lube". Don't use vasaline, you will case the o'rings to break down....
bosco0633
  • Look into my eyes
« Reply #6 on: March 29, 2005, 09:12:15 pm »
Magic lube????????????????
are we still talking about o rings for hot tubs?
;D
autoplay
« Reply #7 on: March 29, 2005, 09:30:03 pm »
Thx all!  I used the teflon lube stuff. I had some laying around for use on the pool equipment.
When I took em apart,I noticed a little wear on the inner plastic parts,almost as if they were scratched from dirt/sand etc.  They still function perfectly,so not too concerned at this point. Possibly in the future,can see needing new valves. Wondering,would I need to use a new "plastic sleeve" where the plastic globe part of the valve makes contact?
In the worse case,I'll engineer my own,possibly outta stainless steel.  I'll check with Chas,and or a Caldera dealer,and see what parts are out there.
Thx again all,Rich
« Reply #8 on: March 30, 2005, 08:55:46 am »
I am a Caldera dealer, but I have no idea. If they are the same as HotSpring valves, then the wear is normal, and shouldn't cause a problem as long as you open them every once in a while and keep the sand and grit out of them.
This is one area where I can see a real difference between the HotSpring and Tiger River spas: the Tigers don't have the 100% no-bypass filtration, so they tend to get grit into the diverter valves. I usually show the owners how to clean them out - it's not tough to do - so they can prevent a problem.  A HotSpring hardly ever does this because there is never unfiltered water going through the pipes.
