Author Topic: Hot Springs 04 vs 05 Sovereign  (Read 2263 times)
Michigander
« on: March 18, 2005, 10:40:18 am »
I met with our local HS dealer and wet tested the 04 Sovereign.  I thought the seat layout and the jets were very good.  Best feel of the 4 tubs we have wet tested.  What I did not like was I had to choose which jets to run.  I asked the simple question if you could get all the jets to run at once.  The salesman replied "which seat are you going to sit in?"  It just happened that my wife and I were in different seats that would not work at the same time.  The lounger in the Sovereign I could actually sit in without floating away.  I did not think the lounger would be a big deal but I really do like it.
My question to all of you in the know.
The 05 Sovereign has a bigger pump (2.5 vs 1.65) does this support all the jets running at the same time?
BTW.  We were quoted $6200 for the 04 floor model steps, cover, chemicals (no lift).  And $7500 for the 05 same config. Thoughts and opinions about the price always welcome.
My Location is Ann Arbor Michigan.
kvnlaw
Re: Hot Springs 04 vs 05 Sovereign
« Reply #1 on: March 18, 2005, 10:01:07 pm »
The only real difference is the drain.  The '04 has the bigger motor already, unless it's Endurol(white) or an "03.
