Author Topic: effervescence  (Read 4774 times)
txwillie
effervescence
« on: March 17, 2005, 11:54:50 am »
Is it normal for the water to be really cloudy with the pumps on high and air induction on? My tub looks like a glass with alka seltzer in it with everything going, but is crystal clear within a minute or so after everything shuts off and the little bubbles dissipate.
Just wondering.
txwillie
effervescence
Gary
Re: effervescence
« Reply #1 on: March 17, 2005, 11:59:44 am »
It is called turbidity and it is unusually caused by the total dissolved solids (TSD) being too high. It is a good sign to do a drain.
Gary
Re: effervescence
« Reply #2 on: March 17, 2005, 12:06:24 pm »
Gary
Gary is dead on. After about 3 months (currently) my water does the same. I might get good enough weather to change it .
spahappy
Re: effervescence
« Reply #3 on: March 18, 2005, 01:56:19 am »
It's like your water feels heavy when you're in your tub.
And the first soak with fresh water, you'll wonder why you waited so long.
Spahappy :D
Re: effervescence
« Reply #4 on: March 18, 2005, 08:06:11 am »
Spahappy :D
Your right about noticing the difference when you change. However, I don't have to wonder why I waited. This winter weather has been the main reason. I start draining tonight after our soak and clean and refill in the morning
steve771
Re: effervescence
« Reply #5 on: March 18, 2005, 10:46:36 am »
Now wait a sec...  There has to be some "cloudiness" when the bubbles are passing thru the water.  That's just what happens.  I suppose there could be an excess at some point though.  Are you guys telling me that you have crystal clear water even when your jets are on?  ???
Re: effervescence
« Reply #6 on: March 18, 2005, 10:55:37 am »
You are right, to an extent.  With fresh water, and the jets on it is less clear, but its a major difference between how it looks with new water vs 3 month old water.  And there is a huge difference in how long it takes to clear again once the jets are turned off. With new water its almost instantaneous, and with old water it can take a minute or two and you definitely notice the lack of effervesence as TX noted.  The next time you change water, take real notice of this before and after you change. It will help give you a better idea of when you need to change.  Once you get good with chem maintenance and you don't have scum, foam, or santitation problems, this is the easiest thing to look for.
steve771
Re: effervescence
« Reply #7 on: March 18, 2005, 06:08:54 pm »
Oh great... I thought I had just figured out the chemical balance/scum/foam/sanitation and now you throw the effervesence into the mix!  ;) ;D
Does this hot tub challenge never end? ! ?   ;)
« Last Edit: March 18, 2005, 06:09:36 pm by steve771 »
Re: effervescence
