Author Topic: Power Use  (Read 1660 times)
dude
Power Use
« on: March 14, 2005, 10:49:08 pm »
I was wondering, is it cheaper on electricity to turn off the spa at night time after I am finsihed using it, and then power it up a few hours before I want to use it, or just to leave it on all the time.  I live in a hot climate where the water will be in the mid-90s during the day without the heater, and mid-80s at night.
Power Use
Re: Power Use
« Reply #1 on: March 14, 2005, 11:10:42 pm »
Ahhh, you're from my area! ;D
Electricity cost may still be a factor in your location and cooling the water too much and reheating it can be expensive if you are continually doing this more than 4 or 5 degrees.
I suggest lowering the temperature a few degrees during the day at max.
Then again, what the h*ll do I know about this? ??? ;D
(Alberta Canada) :D
Re: Power Use
« Reply #2 on: March 15, 2005, 12:02:59 am »
I wouldn't power off the spa, you might not get enough filter action.  If you use the spa more than a couple times per week, you probably won't save enough to make the temperature thing worth it.
You could always try and see, though.  Depends a lot on your electric rates and usage pattern.
Re: Power Use
