Author Topic: Outside Pump?  (Read 7692 times)
poolboy34
Re: Outside Pump?
« Reply #15 on: March 09, 2005, 03:42:43 pm »
ok.....call me crazy, or just not well informed...but most GOOD manufacturers have an Equipment compartment/shroud that seperates all the main boards, pumps, circ pump, heater, etc from the rest of the spa for easy access.  So please tell me how having this outside of the spa is any more advantageous????
Also, are the steps that the equipment is under on the PDC spas attached to the spa????  I don't recall ever seeing a picture of a PDC spa without steps.
Re: Outside Pump?
HotTubMan
  • My 2.1 cents, eh
Re: Outside Pump?
« Reply #16 on: March 09, 2005, 04:01:01 pm »
ok.....call me crazy, .
Ok, you asked for it
Jason you're crazy!!!!!
HTM 8)
Re: Outside Pump?
« Reply #17 on: March 09, 2005, 04:48:52 pm »
The only advantage I see is it allows you to fully foam all 4 sides rather than 3 or 3½. Its a decent idea though separating the equipment into its own housing outside the spa may worry some people regarding freezing.
HotTubMan
  • My 2.1 cents, eh
Re: Outside Pump?
« Reply #18 on: March 09, 2005, 04:55:29 pm »
I used to encounter this fear a great deal as a Beachcomber dealer. I for one do not see much difference between having the equipment behind a wall panel vs. inside a step. Most "doors" to the equipment area have virtually no insulation, if any. Most of them also have ventalation slits.
The Beachcomber Protec step on the other hand actually does have insulation inside it. This move was done mostly for marketing to help lessen the fears of consumers regarding freezing. One true benefit was that the insulation offered a sound deafening effect.
Re: Outside Pump?
