Author Topic: Re: Nature II Cart. ?  (Read 3213 times)
poolboy34
« on: March 02, 2005, 03:03:12 pm »
The nature 2 spa cartridge is a great way to reduce the amount of chlorine (it is NOT compatible with bromine) needed to keep a spa properly sanitized.  When used in conjunction with an ozonator it can possible to reduce the amount of chlorine needed to sanitize a spa to as low as .5ppm.  It also gives the water a softer feel, and is gentler on your skin as well.  The Spa Frog is very similar to the NaTure 2 Spa Cart and can be used with Bromine as well.  It works the same way as the Nature 2 for the pools work(if you are familiar with that).
Jason,
Store Manager for a D-1 & Caldera dealer
starjr13
« Reply #1 on: March 02, 2005, 03:34:19 pm »
We have a Nature 2 - we are using a half cap of Chlorine Concentrate a week with tbsp of shock weekly and ph balancer.
Does that sound correct?
« Reply #2 on: March 02, 2005, 06:53:02 pm »
I have been using the N2 along with a reduced amount of chlorine for over a year. Do I think it is worth it? No not really. I guess the cost is the part that I have a hard time with. If that is not an issue then yes I say go for it, but if your trying to reduce the cost to maintain your tub then you may not see an added benifit that's enough to outweight the cost. I do however like the fact that if I miss a day or two or three I do not have a cloudy water issue, it seems to help keep it clear longer. And for those of us who do take vacations and leave our tub, home alone :) maybe the cost is worth it?
« Reply #3 on: March 03, 2005, 05:53:54 am »
My only concern here Star would be your shock, if it is MPS shock that is nowhere near enough to truely oxidize your tub, which is the purpose of a shock. After a while of adding chlorine and dead stuff the chlorine killed to your water a good strong shock is the perfect cure for ailing water. The way I like to look at it is 3-5 PPM of chorine after a soak will kill the nastys and that will dissapate overnight or so. 10-20 PPM will kill everything oxidize your water and give you a fresh start. Make sure you allow the 10-20 PPM to offgas and circulate for 1/2 hour before you cover your tub.
