Author Topic: Temperatures over 104  (Read 14280 times)
tonyp
  • Soaking in a HS Envoy!
Re: Temperatures over 104
« Reply #15 on: March 02, 2005, 12:31:26 pm »
Can the HS display actual temperature.  My Envoy seems only to display set temperature.
If so how?
JTJ23BA
  • I love my HotSpring!!!
« Reply #16 on: March 02, 2005, 10:20:16 pm »
Tony, no it wont show actual temp.
« Reply #17 on: March 02, 2005, 11:11:47 pm »
The display is designed to show the temperature which you have the tub set for. And if the temperature of the water is within a couple of degrees of the set point, the green 'ready' light comes on.
The display goes blank after a moment - and if you press the + or - it comes on first showing you the set point, then additional touches on the + or - will change the setting.
