Author Topic: Sump Pumps  (Read 4592 times)
Warkovision
  • West and Wewaxsation, at Wast!
Sump Pumps
« on: January 26, 2005, 06:48:40 pm »
OK. I know this has been covered - and I did do a three year search on the subject, but didn't find the info I was after. I'm due for a water change and rather than use the gravity drain, thought I would go the pump route. I saw Steve's post about just using a hose (pool vacuum type) to syphon out the water, but our tub is on the ground and I don't believe I can get the hose low enough in relation to the tub to be effective. My question is, what brand or variety pump would you recommend and what accessories? (hose adapter, etc.) And where's the best place to purchase such a thing? I saw where someone suggested an oil free pump because of the chance of leakage with one that has oil. Anyhow, thanks.
Sump Pumps
Re: Sump Pumps
« Reply #1 on: January 26, 2005, 07:00:42 pm »
Hey Wark! That concept of using a vacuum has no bearing on the spas position or depth. Once the flow has been established by use of a shop vac, it will flow freely from that point on without suction. You'll just need a weight of some sort to keep it in the footwell.
If you are considering a sump, any basic unit will do and I don't believe special consideration needs to be looked at for this application. These usually come with the required fittings to hook up to the unit itself. I don't have any brand names to forward to you but keep it simple and inexpensive. It'll do the job for ya!
Russ
Re: Sump Pumps
« Reply #2 on: January 26, 2005, 07:02:51 pm »
good info at homedepot.com
do a search on sump pumps
then click on the info page.
Warkovision
Re: Sump Pumps
« Reply #3 on: January 26, 2005, 07:55:39 pm »
Thanks guys,
  Maybe I'll just buy the pump connection hose first and see if I can make the syphon trick work. Then move on to the pump if that fails, :)
gb60
  • No matter where you go, there you are.
Re: Sump Pumps
« Reply #4 on: January 26, 2005, 11:42:22 pm »
I'm just a newb, but here's what I did...
I bought a 24' sump pump discharge hose ($7 everywhere), held one end tight to a handy jet, ran the pump for 10 seconds, and voila!!
UnderTheStars
Re: Sump Pumps
« Reply #5 on: January 27, 2005, 05:16:20 am »
Good plan Warko!  My 400 gallon tub sits on the ground, yard is flat.   The $7 sump discharge hose (no pump) empties it in 15 minutes.   8)
nicker
Re: Sump Pumps
« Reply #6 on: January 27, 2005, 08:47:29 am »
lucky for me my drain hole is much larger then most spas so I can drain my tub (about 275 gal) in about 20 minutes.  My drain is about 1 1/2".
But I have heard the sump pump works great and FAST probably becuase it to has a large capacity hose.  And that is good especially if you live in a cold climate as to get the empty and refill done quickly.   I have hear others use the tub drain along with a garden hose at the same time and that speeds it up.  But I think the sump pump would be the quickest. I just bought one for our house at Home Depot for $130 Cnd funds.
Elle
  • Underpromise; overdeliver.
Re: Sump Pumps
« Reply #7 on: January 27, 2005, 09:16:33 am »
Maybe I'm just being a girl who knows little about sump pumps and the like, but where does the water go when you are draining with such a short hose  (24") ?  Am I missing something here?  My tub sits on the ground, and the one time I drained it I ran a long hose to the back corner of my lot where the drainage sewer is located and hung the end of the hose down into it.  Would I  need a larger, but equally long, hose to drain faster?  Can someone set me straight?
Elle...giving women everywhere a bad name
Re: Sump Pumps
« Reply #8 on: January 27, 2005, 09:44:49 am »
Being that your a newbie, that can't have any merit  ;D
I might try that next time.  Something simple I didn't think of doing.
« Last Edit: January 27, 2005, 11:21:23 am by wmccall »
bulmer4nc
  • Now a Canes Fan.
Re: Sump Pumps
« Reply #9 on: January 27, 2005, 11:18:54 am »
Think he said a 24' hose (24 feet)...  That should be lots for most people.  We actually need about 50 feet to get the back of our yard so I'd need 2.
Anyone know if the sump pump hoses can be connected together?
nicker
Re: Sump Pumps
« Reply #10 on: January 27, 2005, 11:32:12 am »
Dont you just drain the water onto your yard/lawn ???  That is what I do.  I don't add any chems to my tub for a couple days before I drain as to try no to kill my lawn.  So far so good my lawn is still green.
Re: Sump Pumps
« Reply #11 on: January 27, 2005, 11:58:02 am »
Same for me. A couple of weeks ago I wouldn't have wanted to add 425 gallons to my lawn, but normally it isn't a problem.
ebirrane
Re: Sump Pumps
« Reply #12 on: January 27, 2005, 12:02:50 pm »
Yeah. leave it to a guy to state that 24" will stretch across the whole yard...
-Ed
bulmer4nc
  • Now a Canes Fan.
Re: Sump Pumps
« Reply #13 on: January 27, 2005, 01:19:23 pm »
Right now we're using Bromine and keep the levels up right until we drain.  We've got a drainage easement right on the other side of our back fence so we just run the hose and stick it under the fense.  That way the're no risk of doing anything to the grass...
Elle
Re: Sump Pumps
« Reply #14 on: January 27, 2005, 04:55:16 pm »
Dear hubby would take off my head if I drained the spa onto his precious lawn.  Not going to happen on my watch.  :)
Elle
Re: Sump Pumps
