Author Topic: gfi operation  (Read 2357 times)
t6texan
  • Tiger River Begal
gfi operation
« on: January 24, 2005, 10:20:14 pm »
have a question? have 2001 tiger river bengal, went to use it hte other nite . the red power light on spa pannel was blinking.  spas wasnt up to temp it was onley 99 degrees. but set to heat to 102 degress . looked over at gfi plug pushed it in it wassnt fully pluged in. i gues my dogs got to rambunctios around it and bumped it loose. now the question how do i tell if gfi is working normaly?
tanks t6texan
gfi operation
Re: gfi operation
« Reply #1 on: January 24, 2005, 11:12:24 pm »
To see if your GFI is working correctly, simply press the 'test' button. If the other button pops out and the power is shut off to the spa, then the GFI is working normally. Push the 'reset' button to get things going again. The red light could not have been flashing if there was no power to the tub.
The red light flashes when the heater gets too hot. This is normally caused by a dirty spa filter. Shut off the power to the tub, remove and clean the filter, replace and turn the power back on. Should be fine.
Re: gfi operation
