Original
Micro Clean Filter for Optima
Pages: [
Topic: Micro Clean Filter for Optima (Read 3990 times)
Max78
on:
January 09, 2005, 06:14:15 pm »
Just drained my Optima tub today and am refilling. I ordered a new Micro Clean filter from my dealer but it won't be here for a few days (he is about an hour and a half from here). My present Micro Clean filter is looking pretty bad (4 months old) and is starting to fall apart. My question is: Is it better to use the old Micro Clean filter til my new one arrives or should I not use old one at all? Would it interfere with the operation of the tub without a Micro Clean filter if I waited til my new one arrrived?
on:
Ultimate Member
Re: Micro Clean Filter for Optima
Reply #1 on:
January 10, 2005, 08:17:39 am »
Your micro filter is on the line with your heater and circulation pump. My circ pump is set for 24/7, so it's always on. Your call if you want to run unfiltered water for a few days. Not sure I'd want to myself, but I usually go on the conservative side for these things.
I personally would not re use the old filter if it's in the bad shape you say.
Brewman.
hottubber
Full Member
Hottubbing under the stars...PRICELE SS
Reply #2 on:
January 10, 2005, 12:42:23 pm »
I think that providing you don't have any debris in the hot tub presenylt, you are OK for a couple of days without the Microclean filter. Do yourself a favor, get 2 or 3 of them so this won't happen again. Your larger reemay filter will handle the bather load in the meantime.
Best of luck...
hottubber
Full Member
Reply #3 on:
January 10, 2005, 12:46:01 pm »
I agree with Brewman. If the micro filter is already falling apart, don't re-use it. The larger reemay filter will handle most of the other debris in the water. Get yourself a couple of spare micro filters so you don't run into this again.
Best of luck...
Max78
Reply #4 on:
January 10, 2005, 02:43:41 pm »
Thanks for the replies. I went ahead and put the filter in back last night when it was time to turn the power back on but I will probably go out and remove the Micro Filter. I did order a couple of filters yesterday and they should be here in the next couple of days. I just wasn't sure if not having the micro filter would interfere with any of the operations of the tub but if it doesn't, then I will probably just remove it for the time being.
cparlf
Junior Member
Reply #5 on:
January 10, 2005, 04:27:29 pm »
Speaking of micro clean filters...how do I know when to change it? Mine have never looked as if they were falling apart, but did get yucky brown / tanish in color. I have been through three since August. Do they lose efficiency or worse if they are left in too long?
ttodd1
Full Member
Life is so much better in my Cameo
Reply #6 on:
January 10, 2005, 07:13:45 pm »
Sundance says change them every 3 months. One site online that sells them said every month. Alot will depend on how much you use your tub (ie: how much "stuff" gets introduced to it).
Ultimate Member
Reply #7 on:
January 10, 2005, 08:34:38 pm »
I change mine every water change. Which works out to about 4 times per year. My pre winter water change needs to last from the end of October to early March, so I go about 4 months on that one.
Ultimate Member
2002 Optima
Reply #8 on:
January 11, 2005, 11:46:14 am »
I also change mine every four months. I would keep the old filter in until the new one arrives.
doodoo
Full Member
Sundance Optima Owner - and lovin' it
Reply #9 on:
January 11, 2005, 02:15:30 pm »
I've been changing my micro filter once a month.
My dealer recommended that I do this ( I know some of you will say that that is so he can make more money off of me ) but hey. I also replace my pleated filter once a month at the same time by cleaning it out and letting it rest. I have two of those which I switch back and forth.
Ultimate Member
Reply #10 on:
January 11, 2005, 02:50:36 pm »
It's your spa, and your dough. At one month, my micro filter is barely dirty.
Ultimate Member
2002 Optima
Reply #11 on:
January 11, 2005, 04:14:23 pm »
Sundance recommends three months. I swap out at four months when I change my water, but I could easily go longer. I also clean my pleated filter monthly, but hardly ever need to rinse it in between cleannings.
Reply #11 on:
Pages: [
Original
