Author Topic: Branded Chemicals  (Read 1534 times)
matthewc
Branded Chemicals
« on: January 10, 2005, 03:16:15 pm »
Should I stick with the bigger brands when buying chemicals such as Bromine tablets and PH Minus(Dry Acid)? Or are they all the same? I can buy a 5Kg tub of Bromine tablets from a manufacturer called Champion for £38, whereas 1Kg from Sunspot cost £17.
Any thoughts?
Branded Chemicals
huh?
  • "42"
Re: Branded Chemicals
« Reply #1 on: January 10, 2005, 04:40:39 pm »
Compare ingredients and percentages.  Typically the bigger names will be more concentrated= you will use less.
