Original
To dilute or not to dilute. That is the question?
Pages: [
Topic: To dilute or not to dilute. That is the question? (Read 3197 times)
matthewc
on:
January 06, 2005, 02:37:56 pm »
My local dealer says that it is OK to add chemicals to the tub without first diluting in water. However the instructions on the chemical pt say to dilute in water first.
What do you all do?
on:
Global Moderator
Mentor Level Member
Re: To dilute or not to dilute. That is the questi
Reply #1 on:
January 06, 2005, 02:55:17 pm »
I pour mine into the middle of the tub and run the jets on low for a few minutes. Then I look to see if I spilled any on the surface of the near where I stand.
Last Edit: January 06, 2005, 02:56:06 pm by wmccall
salesdvl
Senior Member
Reply #2 on:
January 06, 2005, 02:58:25 pm »
I cant think of a chemical that would absolutely need to be diluted into a spa. It is important for a vinyl liner pool to not have solid chemicals come in contact but spa shells are diff.
I say "NOT" to the original question.
Measure once, cut twice.
HotTubMan
Senior Member
My 2.1 cents, eh
Reply #3 on:
January 06, 2005, 03:52:19 pm »
Good advice above.
windsurfdog
Senior Member
Loving this cool weather....
Reply #4 on:
January 06, 2005, 05:15:13 pm »
The only one you 'might' consider dissolving before applying may be dry acid......
rocket
Full Member
Life is good!
Reply #5 on:
January 06, 2005, 05:23:21 pm »
Soft tubs or spas with like liners do require diluting of the chemicals. Otherwise, put jet pump on high and broadcast the chemicals into the water.
Reply #5 on:
Pages: [
Original
