Author Topic: Del Ozonators?  (Read 3323 times)
envoy
Del Ozonators?
« on: December 28, 2004, 05:23:43 pm »
I just ordered a  Del Platinum SpaEclipse ozonator for my hot tub. Looks to be a 5 min. install at best. My question is ....does anyone have one on their Spa? This was a $155.00 ozonator compared to $500.00 for A "Freshwater III" from Hot Springs.
Thanks..... Daryl
Del Ozonators?
Chris_H
Re: Del Ozonators?
« Reply #1 on: December 28, 2004, 05:33:14 pm »
Just curious, will the ozonator you purchased plug in just like the Freshwater III ozone?
envoy
Re: Del Ozonators?
« Reply #2 on: December 28, 2004, 05:52:44 pm »
Yes, there will be small receptical that is prewired on the Hot Springs IQ 2020 panel. It will get voltage from that and the small tubing line will hook on to the injector. I ordered the injector also......It will be very simple to install on A HS spa.
« Last Edit: December 28, 2004, 06:16:57 pm by envoy »
salesdvl
Re: Del Ozonators?
« Reply #3 on: December 28, 2004, 07:13:00 pm »
The only issue I see assuming it will plug in, is that Hot Spring does not warranty things damaged by ozonators that are under the cabinet that are not theirs.  So if you do this, beware that you may encounter a problem if you need service and the technician sees a "foreign" ozonator.
Measure once, cut twice.
stuart
Re: Del Ozonators?
« Reply #4 on: December 28, 2004, 07:35:58 pm »
Thanks..... Daryl
You know, after reading what Salesdvl wrote I remembered the clause in the warranty concerning an aftermarket Ozone.
My question is what makes the Freshwater II so expensive? I know that sounds like a strange question coming from me (having sold them) but I was just setting here thinking about this and for the life of me I can't see what makes that so much higher priced than other units......?
I'm willing to be sold on the reasons if someone can give me the better points of that ozone to justify the price..... ???
salesdvl
Re: Del Ozonators?
« Reply #5 on: December 28, 2004, 08:28:53 pm »
Simple.... Watkins makes it.  No other explanation is needed.  ( Please do not miss the sarcasm that is intended.)   :)
envoy
Re: Del Ozonators?
« Reply #6 on: December 28, 2004, 08:47:27 pm »
My local HS dealer installs aftermarket ozonators on the tubs they sell. They use PROZONE UV ozonators and wanted to include one with my package......I'm not crazy about a UV ozonator.
stuart
Re: Del Ozonators?
« Reply #7 on: December 28, 2004, 09:13:52 pm »
Don't worry, I didn't! ;)
BTW, where have you been lately
Re: Del Ozonators?
