Author Topic: Cloudy Water  (Read 2415 times)
riddler
Cloudy Water
« on: December 22, 2004, 05:28:40 pm »
Seems like within a day or two I had crystal clear water turn cloudy . I checked all the chems to make sure they were where they needed to be, I also did a filter change and I even added some water clarifier to the mix. How long will it take to clear up , or is it going to take a water change to correct this . It has been about  three months with the water thats in the tub now.
Cloudy Water
Re: Cloudy Water
« Reply #1 on: December 22, 2004, 06:24:14 pm »
At 3months, you may be fighting a losing battle.
Re: Cloudy Water
« Reply #2 on: December 22, 2004, 07:30:10 pm »
Change the water. It's the cheapest chem you can add to your tub, and is generally the most effective.
8)
stuart
Re: Cloudy Water
« Reply #3 on: December 22, 2004, 09:09:49 pm »
 8)
There is a very special clarifying chemical that you should use at times like this that beats tons of other products....
It's called H2O...
Re: Cloudy Water
