Author Topic: Filtration  (Read 9485 times)
matthewc
Filtration
« on: November 29, 2004, 03:02:04 pm »
Hi Guys
I have recently had a power cut and all of my control pannel settings have gone back to default. Can anyone tell me how long i should run my filtration and Ozonator for per day?
MAtt
Filtration
Re: Filtration
« Reply #1 on: November 29, 2004, 03:07:44 pm »
Make and model?
Size?
Do you recall about how much you had them running before? I always say to run the filter the shortest amount which keeps the water looking the way you want it.
Re: Filtration
« Reply #2 on: November 29, 2004, 03:11:00 pm »
Make and model?
Size?
Agreeing with the ever-wise Chas.  One additional question, how long have you owned your tub? My filtration is settable in 2 hour increments from 0-24 hours.  Initially I found a setting of 10 hours a day kept the water in good shape. But after a year of that and getting a better idea of how to keep my water in good shape I have dropped that back to 8 hours a day.
windsurfdog
Re: Filtration
« Reply #3 on: November 29, 2004, 03:13:19 pm »
Hopefully there is a default schedule programmed into the controller (my controller has such)....if so, try it and see if it will satisfy your requirements.  Good luck.
8)
matthewc
Re: Filtration
« Reply #4 on: November 29, 2004, 03:24:59 pm »
Hi Guys
Sorry for the lack of info.
My tub is a Nordic Rendezvous which holds about 1800L.
The control pannel manual says that the filters will always run at 12 hour intervals, but that you can change the time on from 0 to 12 hours. After a power cut it reverts to 4 hours on twice a day. However as this is standard for the SpaBuilders controller it may not be best for my tub. I have had the tub for about 2 months and so far the water looks pretty good. My guess is that the supplier i brought it from just leaves it at the standard time, but i would like to be a bit more scientific if possible.
Matt
hawkman
Re: Filtration
« Reply #5 on: November 29, 2004, 03:47:04 pm »
Why is it that the Hot Springs dont come on during the day for a cycle and only rely on the circulation pump?  ???
Re: Filtration
« Reply #6 on: November 29, 2004, 04:14:55 pm »
Two reasons: one, they have a constant flow through one of the filters via a small circ pump. That tends to do a small amount of filtering on an ongoing basis.
Then, they have lots of filtration when the jets are running. They filter all the water which the pumps move, not just a portion of it.
As a result, most people don't need additional filtration cycles. But if you find you want a cycle, you can hit the 'clean' button and run the jets for about ten minutes. That will do what other tubs take an hour or more to do.
And they have found that you usually only need such extra cycles in ralation to use: meaning usually after you get out of the tub.
It works quite well, actually.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: Filtration
« Reply #7 on: November 29, 2004, 04:48:27 pm »
How is it filtering more in ten minutes than other spas that are filtering for an hour or more?
Re: Filtration
« Reply #8 on: November 29, 2004, 05:24:32 pm »
Because HS tubs do not bypass the filters. All the water the pumps move is going through a filter. On a spa with a single filter, such as our Tiger River tubs for example, you move about the same amount of water, but you will filter only half, or less. Much less as the filte gets loaded up.
So - you can filter in ten minutes what a bypass tub will take an hour or more to do. Why do you think so many people post here saying that they have to run their spas four hours, twice a day - or more - to keep the water clean?
windsurfdog
Re: Filtration
« Reply #9 on: November 30, 2004, 08:28:17 am »
Chas,
If left unattended for a 24 hour period, do the HotSprings therapy pumps come on automatically for a period of time or does just the 24 circ pump run by itself for the entire period? ???
poolboy34
Re: Filtration
« Reply #10 on: November 30, 2004, 11:51:30 am »
Ok, so no water bypasses the filters when the jet pumps are on..................playing devils advocate, what happens if by chance someone gets their hair, bathing suit, shirt sleeve etc...caught in the filter well????  There must be some sort of safety measure that senses a restriction of flow that would shut the pumps off????  I have heard this in sales seminars and feel that it is a scare tactic, which btw we do not use and I will add that I hope no one would stoop to using scare tactics to sell their product.
windsurfdog
Re: Filtration
« Reply #11 on: November 30, 2004, 12:11:04 pm »
.....hence the emergency pair of scissors located in the filter compartment....... ;D
Re: Filtration
« Reply #12 on: November 30, 2004, 12:20:59 pm »
Well, I have a two-fold answer. One, our tubs (And Jacuzzi) were the very first tubs to be UL listed. We helped write the UL standard, as well as the ANSI standard. Now - even though our tubs are listed through ETL - we still build and test to that same UL standard, which has been updated over the years for better safety. As a result, we couldn't send tubs out which could trap people.
If you want a scare tactic,  look at in-ground tubs, particularly older concrete/gunite ones. Those are the only ones which have harmed people in suction accidients. And even then, it almost always happened as a result of somebody removing a floor drain cover or a repairman who removed a valve or installed a different pump.. this stuff just doesn't involve self-contained spas, UL listed or not.
Secondly, take an honest look at a HotSpring spa filter area. There are vents near the bottom of the filter area, there is a sliding weir, and a cover which lifts off. And inside, are two, three, four or even five filters - depending on model. All HotSpring tubs have two filters (or more) per jet pump. So if you somehow manage to form yourself into a non-human shape and do, in fact, manage to get yourself wrapped around one of the filters, you will only feel the slightest motion as the water simply begins to flow from the other filter or filters.
The filters draw from a surface area of 30 to 60 feet, and have more filters on the same line.  Try it yourself: go to a showroom and run the jets on any HS tub. Try the HP models for the max flow - that would be an Envoy or a Vista. Run all the pumps, open the filter lid and put your hand on one of the filters. You will not feel suction - you might feel water flow, but you will not feel suction.  Now as you're standing there, try to imagine how on earth you would ever wrap yourself around two or more of those filters at the same time... And hair is not an issure either, as the pleats have a limited depth which cannot grab onto  hair.
Re: Filtration
« Reply #13 on: November 30, 2004, 12:25:06 pm »
But if some mischevious teenagers decided to remove the filters, then stick their heads into the intake, by golly you'd have a real mess on your hands!
(This was actually stated by the one who shall not be mentioned.)
Re: Filtration
« Reply #14 on: November 30, 2004, 12:28:22 pm »
Well, this is what I like to refer to as, "error." Some would call it an easily proven lie....
Go ahead: take the filter(s) out. You will be looking at a plastic standpipe with carefully designed grills up and down all sides - still safe. The UL testers are generally smarter than your average teenager...
Re: Filtration
