Author Topic: where to find an obscure item....  (Read 6748 times)
anne
« on: March 27, 2006, 01:46:19 pm »
This is hot tub related is a vague way......as I work on my yard and new patio, I'm irritated by a project I never finished for my screen room.  My problem: this screen room was built a long time ago (1960ish). The screen material is held in the grooves by that rubbery- cord- lake material, called spline, I think. When I moved in three years ago, I painted the inside of the screen room, and to do this, i had to pull out a lot of the screen material. It was old, and I planned to replace it all, anyway. I threw out the spline as it was old and dried, and I figured I could easily get more. Not so easy.
I have looked everywhere I can think of, I have asked hardware stores if they can special order, but I CANNOT find the right size spline. The closest out there is 0.185 (4.6mm) and it is enough too small that it will not work.
So now I have a screen room with about 1/2 the screens missing.....anyone know where to buy archaic sized spline? or have other ideas? I tried doubling the screen material over in the groove to create a tighter fit- way too cumbersome. I tried to find different thicknesses of screen- No go.
thanks!!!!
Dance like nobody's watching
Re: where to find an obscure item....
« Reply #1 on: March 27, 2006, 02:07:46 pm »
thanks!!!!
What size do you need?
for example, here's a place that sells .225
Is it larger than a quarter of an inch?
http://remodelist.com/product.php?productid=40596
anne
« Reply #2 on: March 27, 2006, 02:15:09 pm »
I dont know exactly what size it is, but it is bigger than .185 and smaller than .225. Thanks, though!
« Reply #3 on: March 27, 2006, 02:40:00 pm »
Have you ever replaced screens before? The spline is usually very tight and you need the pizza wheel roller to get it going.
(I'm not trying to be a smart a$$ or insult you, it's just that this is so odd, I've never heard of this).
The other idea is go to a place that repairs screens (Small hardware store) bring in one screen and see what the do or have to say.
« Last Edit: March 27, 2006, 02:42:16 pm by drewstar »
« Reply #4 on: March 27, 2006, 03:10:34 pm »
 The other part of the equation is screen material.   I wonder aloud if you must use metal screening and the larger size spline (.185).  Would the thickness of the screen material be enough to make a significant dif? Have you tried a small piece of Al screen with the larger spline?
« Last Edit: March 27, 2006, 03:11:22 pm by drewstar »
« Reply #5 on: March 27, 2006, 04:50:37 pm »
Your suggesting to get thee to the local hardware store was a really good one.  If it can be done, those guys should be able to help.  Assuming you still have a store like that around.  We do, and it's amazing what they can do.
anne
« Reply #6 on: March 27, 2006, 05:10:50 pm »
thanks for your help, everyone:
Drew: no offense taken, and youre right- it is a tight fit when it is in there right, but I dont think my technique is the problem, since I was able to resurrect SOME of the panles using old spline that I did not thow away. (Once I figured out that no more seemed available, I saved the old nasty stuff.)
Aluminum screen in a thought. I had looked at a number of different plastic/synthetic types, but not aluminum. I may do that. I cannot take a screen into anyone, as the windows dont come out- the groove that the spline fits into is part of the structure.
Brewman- my local hardware store people just looked at me funny. I may try to find another store.
I'm going to try a piece of the 0.225 again, and see what happens. It has been a year since I last thought about his project, so maybe it just requires a new approach. :-/
autoplay
« Reply #7 on: March 27, 2006, 08:54:00 pm »
Our screening around our pool requires a flat spline,which comes in two different sizes. Possibly you have the same setup.....and you're trying the round spline...which will NOT work?
Tatooed_Lady
« Reply #8 on: March 27, 2006, 09:37:25 pm »
anne, can you use the smaller spline and just double the screening material over on itself to fill the gap? (doesn't seem like it would LOOK too pretty, though. :( )
RIP C-Rod
« Reply #9 on: March 27, 2006, 09:41:04 pm »
I just installed a screen room and it had a large spline (didn't measure diameter).
One thing to remember is that the rubber may have shrunk a little from the original diameter. I know that over years building "standards" have changed.
Here's a few on-line places:
hardware.hardwarestore.com/31-156-screen-spline/ ribbed-screen-spline-682468.aspx
doityourself.com/store/6443402.htm
www.sillikerglass.com/screening_and_accessories.htm
These might give you a place to start.
I did a google search, maybe try dogpile.
Good Luck!
tootsie
« Reply #10 on: March 28, 2006, 09:50:50 am »
RV's and mobile homes had aluminum screens for a long time if you have a place that sells these close to you they may be able to get it for you.
« Reply #11 on: March 28, 2006, 12:27:57 pm »
Lotsa spline here:
http://hardware.hardwarestore.com/31-156-screen-spline.aspx
Choose wisely, Grasshopper.
Wisoki
  • YEEEEEEhaw
« Reply #12 on: March 28, 2006, 02:22:59 pm »
ANNE, .....you gott a lot a splININ' to do...
Say it like Ricky Ricardo, it's much funnier.
anne
« Reply #13 on: March 28, 2006, 02:53:53 pm »
Thanks all, for your help! I still have not tried the 0.225 again- started storming yesterday afternoon, and the significant other needed a lift to the doctor for a new cast......but I'll tackle it soon, and let you know!
« Reply #14 on: March 30, 2006, 07:17:06 pm »
Make sure your groove is clean and paint free before you try the .225 And make sure you are using a spline tool. If it's still to big get  a router bit maybe and enlarge the groove? Just throwin stuff out there.
