Author Topic: Masterspa LS750  (Read 3355 times)
richie62
Masterspa LS750
« on: November 23, 2004, 05:47:22 pm »
I just had the tub delivered and the electrician can not find the knockout to run the wire through the outside of the tub. anyone that can help?? richierich1962@hotmail.com
Masterspa LS750
windsurfdog
Re: Masterspa LS750
« Reply #1 on: November 23, 2004, 05:59:19 pm »
Congrats on the new spa, richie.....may the goddess of Spatopia bless you with crystal water.
Since my LSX sits on a deck, I wired it through the bottom by drilling a hole through both the plastic bottom pan and the deck at once.  If you are sitting on a slab and need to go through a side panel, I believe you will have to drill or saw a hole through the panel as there are no knockouts that I have seen.  I would suggest you fashion the hole in a panel immediately beside one of the corner panels.  Another possibility to investigate would be to go through the bottom pan below the panels.
Good luck and let us know how it goes.
8)
Re: Masterspa LS750
« Reply #2 on: November 23, 2004, 06:04:37 pm »
Doesn't the installation manual for the spa explain how/where to run the wire thru the cabinet?
Just curious, not trying to start anything, honest.  ;D
stuart
Re: Masterspa LS750
« Reply #3 on: November 23, 2004, 08:05:04 pm »
On either side of the tub facing the front towards the bottom is a little black knockout plug.
richie62
Re: Masterspa LS750
« Reply #4 on: November 23, 2004, 09:27:13 pm »
Thanks for all the help. The owners manual didn't have anything about it, and after several phone calls to other electricians it sounds like you have to put in you own hole! I look forward to the first use!!!
windsurfdog
Re: Masterspa LS750
« Reply #5 on: November 24, 2004, 08:56:39 am »
This is not to start anything about TP v. FF--I'm completely neutral on the subject--but the MS implementation of TP would allow one to enter the cabinet from any side of the spa with the ability to route the conductors in sealtite flex through the cabinet to the controller.  This certainly is advantageous but also is not a reason upon which to base a spa purchase--just consider it a bonus.
8)
Re: Masterspa LS750
