Author Topic: electric hook ups  (Read 3392 times)
sputnick
electric hook ups
« on: November 13, 2004, 06:26:51 pm »
were are having the j-365 . in 2 weeks  :D i have a question
they want $700.00 to hook up the electric is this too much. or a deal or should i look for a diffrent electrician
electric hook ups
ttodd1
  • Life is so much better in my Cameo
Re: electric hook ups
« Reply #1 on: November 13, 2004, 07:47:52 pm »
Alot depends on how far the run is, are they putting in the GFI, are they adding on to the existing breaker box?  Also is this the only quote you got?  I would get at least 2.
« Last Edit: November 13, 2004, 07:48:35 pm by ttodd1 »
« Reply #2 on: November 13, 2004, 11:57:32 pm »
Getting a couple more bids isn't a bad idea, at least you'd know if your bid was reasonable or not.
With the information you provided, it's not possible to say if your estimate is reasonable or not, but if you get more bids and they are all similar, you're probably getting a fair quote.
steve771
« Reply #3 on: November 14, 2004, 12:11:47 am »
Length of run is key, but offhand, it sounds in the ballpark.
HotTubMan
  • My 2.1 cents, eh
« Reply #4 on: November 14, 2004, 11:58:30 am »
$700 sounds good or high, depending on the factors listed above. Get two more quotes.
HTM
tansu
« Reply #5 on: November 14, 2004, 03:36:27 pm »
Also having j-365 in 3 weeks, did my own 50' run for $100. 60A panel came with spa.
« Reply #6 on: November 14, 2004, 03:41:35 pm »
Factors which affect the cost of a wiring job:
Distance
Amperage of the load
Sub panel, shut off or straight, uninterupted run
Customer's attitude
Do you want the entire job to be invisible?
Attic or crawlspace access.
Basement
Going under walkways
Cutting cement
Distance
Upgrading the main panel
Who does the trenching, if needed.
Can they fit it in with other jobs (Work a few hours here and there etc.)
Is the electrician a one-man show or does he have a dozen trucks on the road?
Distance
