Author Topic: MPS SHOCK TREATMENT??  (Read 9963 times)
bobhol
  • delivery in 35 minutes......or its LATE!!!
« on: November 10, 2004, 11:26:27 am »
I am using dichlor to maintain and shock my spa as suggested numerous times on this forum . I t seems to work great but what is this MPS and why should I use it? thanks, bobhol
Re:  MPS SHOCK TREATMENT??
« Reply #1 on: November 10, 2004, 11:54:41 am »
MPS is a non-chlorine shock.  I use Chlorine regularly and once every couple of weeks I use MPS to shock. Others can explain some of the benefits of that.  People that know more than me will tell you MPS adds to your TDS level significantly.   My practical experience is that if my tubs gets a little cloudy, MPS brings it  back faster than Dichlor.  Usually if that happens I'm probably going to change the water in a month or less anyway so I don't worry about the TDS level.
« Last Edit: November 10, 2004, 11:55:15 am by wmccall »
bobhol
« Reply #2 on: November 10, 2004, 12:03:53 pm »
is  Spa-Lite  by Spa Guard an MPS product? I use a pouch of this once a week. The instructions say it is safe to use the tub 15 minutes later. bobhol
HotTubMan
  • My 2.1 cents, eh
« Reply #3 on: November 10, 2004, 12:18:28 pm »
In Canada, Spa-Lite contains:
Dichlor
pH buffer (dichlor is pH7, this buffer makes the addition of chemical pH7.5)
Clarifier
It may have a different formulation in the U.S.
HTM
bobhol
« Reply #4 on: November 10, 2004, 12:24:25 pm »
I AM CANADIAN eh. Sound like a beer commercial? So I guess my peterborough Spa -Lite is the formula what-you -said., but what does MPS stand for and what should I buy ( in Canada). bobhol
empolgation
  • you pay what you get it for
« Reply #5 on: November 10, 2004, 12:25:49 pm »
Spa Lite does contain MSP but it has other stuff as well. It's a blend of MPS, dichlor, a flocculent/clarifier and a "PH buffer".
In essence it's an "all in one" product. I personally believe in the "less is more" approach - control exactly what you put in your water, if you only need to shock than only add shock, if you need a flocculent than add only a flocculent, etc. As for the 15 minutes, that would depend on how much you put in and what the levels are after 15 minutes. 15 minutes seems like a short time for shock to me.
e
poolboy34
« Reply #6 on: November 10, 2004, 12:51:47 pm »
MPS = Mono per-sulfate, or it's also known as Peroxy-mono-sulfate, or also oxy-monoper-sulfate.  MPS in a nutshell is just an oxidizer that breaks down organics and oils in the spa very rapidly.  The benfits are that you can use the spa 15 mins after applying it, and there is no odor to it.  The draw backs are that it lowers the Alkalinity of the water over time, and as some have indicated increases the TDS of the water.  1-2 oz of MPS is usually more then sufficient for a shock treatment.
Jason,
Store Manager for a D-1 & Caldera Dealer
bobhol
« Reply #7 on: November 10, 2004, 02:36:14 pm »
Thanks poolboy34. I have been having a challenge with low alkalinity and maybe the spa -lite is part of it. Can I buy mps  without additives to use as needed. bobhol
HotTubMan
  • My 2.1 cents, eh
« Reply #8 on: November 10, 2004, 02:54:53 pm »
SpaLite will not affect your pH. That is one of the ingredients I listed above. How is your alkalinity?
Are you using chlorine or bromine tabs? These will have a negative affect on pH and TA.
Do you have friends who drink alot of beer and don't leave the tub? Children (12>younger)using the tub?
These types of people will errode your pH too.
HTM
bobhol
« Reply #9 on: November 10, 2004, 03:11:17 pm »
I dont use tabs of any sort. we use the tub daily .my wife and I before we go to bed for 30 minutes or so. since we have had the tub ,about a month , my daughter and boyfriend get in as we are thinking of getting out. (He,s here a lot ,lately) I,ve put 4 t,spoons of dichlor in a small container and they apply  it when they close up the tub. It gets more use on wknds as both my daughters friends show up. I,m tying to keep the water perfect  and I,m learning on the fly. bobhol
« Reply #10 on: November 10, 2004, 04:07:39 pm »
Any adult who get caught "eroding my spa PH" will get permanently banned!  EWW..........
« Last Edit: November 10, 2004, 04:08:18 pm by Brewman »
