Author Topic: Spa temp and energy usage  (Read 18706 times)
Nhbeacon
  • Still a happy Siberian owner
Re: Spa temp and energy usage
« Reply #30 on: October 27, 2004, 08:15:29 pm »
So Sales beat me to the addition of warm bodies to the circulating water, now what happens when the icy mug of beer makes contact with the water? Or when the condensation freezes on the cover while you are in the tub, what does that do to the rate of heat loss? Then when the foam forms on the tub, does that act as an insulator?
I get enough of math word problems with my High school students in my Resource room, funny how the thread went the way of my week. But I think I did learn something.
Jan :)
Maybe the Hokey Pokey is what's all about?
stuart
« Reply #31 on: October 27, 2004, 11:17:59 pm »
Well, I check at home in the morning as I am checking my regular mail ( and trying to decide whether or not to order viagra or some "extensions" ) then I check at night when I get home ( assuming I can get computer time from my 14 y/o son.
I agree with rocket, your a great addition. Although with a name like "rocket" he's probably been on the same viagra website you have!  ;)
Here's a thought for you, try the viagra on your hair and you won't need the extensions! ;D
be carefull with that stuff around a 14 year old boy though, by the time you get it away from him he could wind up with 3rd degree burns on both hands!! ;D ;)
rocket
  • Life is good!
« Reply #32 on: October 27, 2004, 11:25:48 pm »
Not only is this a fun and enjoyable forum but I actually am learning a few things too.  I hope that the otential spa customers enjoy this as much as we do.
« Reply #33 on: October 28, 2004, 12:51:21 am »
Here's the answer to the bodies in the water.
Yes, if the water is at 95 and you have 6 bodies at 98.6 then the bodies will try to warm the water. Now with this said - I'm talking about just sitting there, it's NOT doing anything fun and exciting in the tub - all bets are off then (would there be water left then?); if the bodies have enough energy to continuously make more heat then eventually the bodies will raise the temperature. The body tries to produce heat when it senses a lowering of it's temperature - that's why people shiver.
One of the laws of thermodynamics is that warm bodies will try to warm objects near them. That's why if you sit next to a window (closed!) in the winter you get cold - your body is trying to warm the window.
Windsurfdog, you see how being a Techno Geek is; a pondering thought gets us to explain all the mysteries of life - See I told you a wealth of useless information!
windsurfdog
« Reply #34 on: October 28, 2004, 09:01:50 am »
I wouldn't say useless at all, Vinman.....
Thanks to all that contributed both scientifically and humorously......I certainly agree with rocket, nhbeacon, stuart, salesdvl and others.....this forum is both informational AND enjoyable.  (Now if I could just understand how Wisoki's panties got so wadded.....)
8)
« Reply #35 on: October 28, 2004, 11:17:30 am »
Thanks to all that contributed both scientifically and humorously......I certainly agree with rocket, nhbeacon, stuart, salesdvl and especially Chas.....this forum is both informational AND enjoyable.  (Now if I could just understand how Wisoki's panties got so wadded.....)
 8)
Perhaps he needs to run them through his dishwasher with the dry cycle off and no soap.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #36 on: October 29, 2004, 08:19:17 am »
Heat Loss - calculating the rate of heat loss due to conductance
Q = k A (Tb- Ta) / d, where
Q is the heat lost due to conduction
k is the thermal conductivity of the tub's insulation layer
A is the surface area through which the heat is being lost
Tb is the temperature of the tub
Ta is the temperature of the surrounding air
d is the thickness of the tub's insulating layer
WAAAY to tired to try and plug numbers in this morning.  Maybe after I get out in the fresh air on my first delivery.
Top_Cat
« Reply #37 on: October 29, 2004, 08:54:49 am »
I regularly warm my tub water by having 8 friends with 103 degree fevers get into the tub and pee in the water.
Temp goes from 98 to 99 instantaneously. This makes it a HTP tub, I guess.
« Last Edit: October 29, 2004, 08:57:31 am by Top_Cat »
« Reply #38 on: October 29, 2004, 09:54:43 am »
Then that would make it a linear relationship??
windsurfdog
« Reply #39 on: October 29, 2004, 10:01:33 am »
Good stuff, serj....the only other consideration in actual heat loss then is the cover and how often it is removed.  Seems that your equation is based upon the cover being opened.  I would guess a cover closed equation with time and cover characteristics factored coupled with a cover open equation with time factored would get us close to a total heat loss amount over a given amount of time.  And like Chas and others pointed out, a wind factor should be considered as well.  Once again, trying to boil all of it down, if your equation is valid (and it sure looks good to me), it looks as if tub temperature is but a minor consideration in total heat loss which is a reflection of energy usage.  Food for thought.......
TC, I hope you don't mind when I say that I'll stick to my methods of tub energy consumption and you can have yours!  And please don't be offended should I decline your generous offer for a soak in your tub!
8)
windsurfdog
« Reply #40 on: October 29, 2004, 10:02:34 am »
Good question, Chas!
8)
« Reply #41 on: October 29, 2004, 02:55:01 pm »
Yes it does.
If it was log function it would involve a number to a power:
    n
  e
this is a log function!
Hey maybe being a Techno Geek isn't all that bad!
salesdvl
« Reply #42 on: October 29, 2004, 03:01:19 pm »
I meant to ask this before, Rocket, was that supposed to be "Potential" or "Oriental" ?
Measure once, cut twice.
stuart
« Reply #43 on: October 29, 2004, 03:04:46 pm »
Ya gotta wonder how many times a statement like this  has been made by guys with names like Vinny...? 8) Fugetaboutit!
windsurfdog
« Reply #44 on: October 29, 2004, 03:10:20 pm »
ROFLMAO.........You're slaying me here....... ;D ;D
