Author Topic: Sun Purity  (Read 2091 times)
taraka
Sun Purity
« on: October 26, 2004, 04:06:07 pm »
 Anyone Sundance/ Sweetwater spa owner have the Sun Purity  purifier in there basket?
What do you use for maintance?  MPS or Dichlor??  What do you use to shock?
How much do you use of the chemical?
Sun Purity
Chris_H
Re: Sun Purity
« Reply #1 on: October 26, 2004, 04:13:37 pm »
Yes, it should be in the basket.
Chemicals for maintenance, as long as you have ozone:
If it is used once a day or less:  1 ounce of MPS before each use.  1 ounce of Di-chlor on a weekly basis.
If it is being used more than once a day: Add 1 ounce of Di-chlor after each use, and 2 ounces weekly.
Di-chlor is the shock.
Re: Sun Purity
« Reply #2 on: October 27, 2004, 10:07:54 am »
I use the Sun Purity cartridge.  I add 1 tsp dichlor per person after use and shock weekly with either 2 tblsp dichlor or 2-3 tblsp non chlorine shock or a combination of both.
« Last Edit: October 27, 2004, 10:11:06 am by tony »
CalicoskiesNC
Re: Sun Purity
« Reply #3 on: October 28, 2004, 08:13:15 am »
I use the Sunpurity.  We add 1TBL dichlor each evening and shock with 3TBL dichlor every Sunday evening.  Thats all we use, with the exception of 2oz Spa Defender every 2 wks and occasional correction of pH/TA.
Re: Sun Purity
