Author Topic: Use after Shocking  (Read 1951 times)
nicker
Use after Shocking
« on: October 27, 2004, 08:40:20 pm »
I was wondering how long you should wait after you shock your tub before you can use it.  I use Spa Shock.
It doesn't say on the container.  I usually don't use the tub on the day I shock.   But today I kind of want to.
Use after Shocking
salesdvl
Re: Use after Shocking
« Reply #1 on: October 27, 2004, 08:51:56 pm »
you should get a test kit that tests for whatever active ingredient you are using.  The "Spa Shock" I carry is a potasium based shock.  Which is also called shock and swim so you can go in right away.  If it is a diff ingredient then:   do not go in until the levels have dropped back to the OK range
Measure once, cut twice.
