Author Topic: leisure bay celeberty second motor  (Read 6819 times)
Steve Lockwood
« on: May 28, 2023, 06:33:59 pm »
Just got a free leisure bay 4-5 person tub and ran my 240 power and quick fill plumbing. I replaced the pump attached to the main jets, now trying to find out which 240 pump they use for circulation off the heater. just the 2 pumps and apparently no circulation pump. It has 2 caps on the pump and no plate, just a sticker that says 4.0 hp spl. so any single speed 4.0 hp pump with correct plumbing connectors will work? Will attach a photo of layout later because I cant seem to identify actual model. It has an old balboa vs249r control system I seem to have working, just need to replace the 30A fuse on the board AFTER I replace the bad second motor. The first motor was a lingxiao Model: 56WUA400-II if that helps.
Steve Lockwood
Re: leisure bay celeberty second motor
« Reply #1 on: May 30, 2023, 10:35:49 am »
Im starting to think they got the pumps installed backwards. shouldnt the 2 speed be on on filtration and heater side for low speed circulation?
CanadianSpaTech
« Reply #2 on: June 01, 2023, 07:15:13 am »
Yes if there is no circulation pump then pump 1 should be 2 speed
