Author Topic: Replacing standard jets with more active ones?  (Read 1800 times)
Coach Steve
« on: February 05, 2023, 09:43:06 pm »
Hello,
I have a Coleman 107 /Maax spa that has standard jets and would like to replace some of them with jets that have some sort of movement , rotating, etc. Can this be done without having to upgrade any other equipment? Is the water flow and pressure sufficient to drive those types of jets?
Thank you.
cranbiz
Re: Replacing standard jets with more active ones?
« Reply #1 on: February 06, 2023, 09:47:42 am »
Depends on the pumps. The plumbing will usually be the same but if the pumps are underpowered, that will effect the flow.
