Author Topic: Why does my ph keep rising...  (Read 2126 times)
Gibson00
« on: January 24, 2022, 06:03:15 pm »
Lately having an issue with ph wanting to keep climbing to 8.
New fill of water less than 2 weeks ago.  Clean filters.
Balanced TA to 70, then ph to 7.6-ish.
Chlorine tub, using dichlor (CYA not very high after only 2 weeks or so), with daily levels kept around 2-3ppm with a shock to 10-12ppm every 12 days or so.
Every day my ph is back up around 8 (taylor test kit).  What am I missing??
Re: Why does my ph keep rising...
« Reply #1 on: January 24, 2022, 08:43:28 pm »
80's not to bad, try driving your PH down a bit more.
I meant TA, drop your TA a bit more.
« Last Edit: January 25, 2022, 06:37:14 am by Tman122 »
A.O.
« Reply #2 on: January 24, 2022, 09:53:40 pm »
Drop your TA, I keep mine at about 40.. keeps the PH in check pretty well. And as long as you use the air injectors in your jets, the PH will want to rise.. its normal.
