Original
Frustrating chemical smell from steam...
Pages: [
Topic: Frustrating chemical smell from steam... (Read 2447 times)
Gibson00
Junior Member
on:
January 16, 2022, 06:50:20 pm »
Really not sure what is causing this...
Water 1 month old with Spa Marvel added. Last maybe 10 days I notice the water looks fine, chemical levels good, but the steam off the water has a chemical smell to it.
So I shocked it to 12ppm with dichlor yesterday. Fast forward to tonight, levels (taylor test kit) are:
chlorine - 3.5ppm
TA - 90
ph - 7.6
Steam still has chemical smell. What am I missing?? I never really use MPS, just dichlor. Should I try a shock with MPS, would that clear up something that chlorine doesnt, that could be causing the smell?
on:
A.O.
Full Member
Re: Frustrating chemical smell from steam...
Reply #1 on:
January 16, 2022, 07:09:27 pm »
What is your CYA level and the CC level? Using dichlor to get your FC that high would raise that CYA way high which will counter act the FC to a degree. The smell I'm thinking is a high CC level.
Gibson00
Junior Member
Reply #2 on:
January 16, 2022, 07:19:58 pm »
OK just took three readings with my taylor kit...
free chlorine - 2.5ppm
combined chlorine - 1ppm
CYA - 65
Ultimate Member
If it Ain't Broke
Reply #3 on:
January 17, 2022, 09:18:07 am »
When do you add your dichlor or bleach?
Gibson00
Junior Member
Reply #4 on:
January 17, 2022, 09:20:29 am »
I typically add dichlor after bathing. Usually with the goal to raise it up to roughly 4-5ppm, which would then be back down to 1-3ppm when we get in the next day.
And shock to about 12ppm maybe every 10 days.
A.O.
Full Member
Reply #5 on:
January 17, 2022, 11:47:31 am »
So your Combined chlorine is a bit high at 1 and the CYA is high at 65, I keep mine closer to 30. If you switch to straight liquid chlorine instead of the dichlor you wont keep raising your CYA. I haven't shocked my tub in 10 months, no need.
Here is a good read if you are interested,
https://www.troublefreepool.com/threads/how-do-i-use-chlorine-in-my-spa-or-pool.9670/
Gibson00
Junior Member
Reply #6 on:
January 17, 2022, 12:25:56 pm »
I'm confused as to why you would never need to shock your tub? Even using bleach, wouldn't you still be getting a buildup of chloramines that need to be shocked out every so often??
I've read the info in that link, and as far as I can tell I'm pretty much doing what it says:
"Never let FC drop to Zero for any length of time.
Keep it between 3-6 ppm normally, min of 1 ppm, and shock to 12 ppm once a week
A.O.
Full Member
Reply #7 on:
January 17, 2022, 04:33:36 pm »
I have an ozone system that eats a lot of it, and sunny days I'll leave the cover off it and the UV will eat them too.
And if you are still using the dichlor you are missing a bit, once your CYA gets up to 30 or so you need to switch to straight liquid chlorine so your CYA doesn't keep rising.
Once I get it to that level the only things I use in the tub are liquid chlorine, muriatic acid, and the occasional Total alkalinity increaser in case I knocked it down to far with the MA.
And I dont shock my tub because it doesn't need it, CC's never get above .6 or .8 and like I said if it does I take the top off for a few hours which takes care of it. Dont shock it due to a schedule someone wrote down (that's what the chemical sellers want you to do) , only shock it if it needs it. At least that's the way I do it.
Last Edit: January 17, 2022, 04:38:26 pm by A.O.
Gibson00
Junior Member
Reply #8 on:
January 18, 2022, 02:20:25 pm »
OK, thanks.
I had been trying the dichlor to bleach method, but like some others have experienced, the bleach (plain clorox) would always push my ph way up, so I was constantly having to add ph down. I just ended up going back to dichlor...
Reply #8 on:
Pages: [
Original
