Author Topic: Caldera Vacanza 2015 not heating (cpanel works, pumps work, Start blinks, no err  (Read 1518 times)
3dron
I am getting no heating but all the cleaning timer functions keep running fine.
Pumps run at all range settings from circulate to full.
I have checking if filter blocked/dirty/greasy.  Even tested without filter.
I have powered off for 1 minute and turned breaker back on.
On power on no error codes, it just comes up to full menu with START blinking.
I have Ohm tested both Heat Sensor and Hi Limit with Ohm meter set to 20k
Temperature sensor (wire feeds under tub) reading is 1 without movement.
Is this reading broken or just because the sensor is touching such cold water?
I read 0 would be cracked/ broken (cpanel read 50°)
Hi Limit sensor which I can see is attached to metal pipe right below control panel reads 11.83
I jumped the heat sensor cboard pins, powered back on and it reads 115° on cpanel but START still blinks.  I tried running through the pump levels and clean setting shortly.  But it still blinks START.
At this point I just unjumped.  Should I still let it run jumped to see if the water heats?  Or should the START stop blinking immediately if the sensor was an issues?
