Author Topic: limelight 220 conversion  (Read 3696 times)
brianls72
« on: October 29, 2021, 09:23:58 pm »
Just converted my Limelight Beam from 110 to 220. Had an electrician do all the wiring. Heater works and jets work, just not together. The jumper on the terminal block was repositioned correctly  Read something in the manual about soft jumpers being programed. Are those in the control box or is it done on the topside screen? Is it something I can do or only a dealer?
Re: limelight 220 conversion
« Reply #1 on: October 31, 2021, 09:29:46 pm »
You need to go in service mode and adjust the jumper to convert the heater to 220 V. To get In service mode on the PC board there is a little black button that looks about the size of a pencil eraser. Push that. That gets you in service mode. Adjust proper soft jumper and you should be good to go
brianls72
« Reply #2 on: November 02, 2021, 09:39:53 am »
Thanks, that did the trick
