Author Topic: Bromine tabs (without Chloro?)  (Read 1808 times)
CV3720
« on: July 29, 2021, 01:26:48 pm »
So, all along I thought I was using Bromine tabs in my hot tub.
I just read the ingredients and there's "Chloro" in there. I went online, and it appears most have that formulation.
What's up with this?
Re: Bromine tabs (without Chloro?)
« Reply #1 on: July 29, 2021, 01:47:42 pm »
So many times I've seen/heard people say they use Bromine tabs because they perceive that they have an issue with chlorine (probably actually true about 15% of the time). In reality Bromine tablets always have chlorine as an ingredient and in fact if you use them and the water gets away from you a little (maybe not enough tabs, not enough water flow though the tablet holder, forgot to replenish, over-usage due to a party...) the solution is to toss in some chlorine granules to temporarily prop up the sanitizing.
CV3720
« Reply #2 on: July 30, 2021, 09:18:07 am »
Is there some ratio of Bromo/Chloro to look for?
