Author Topic: Hot Sprint Sorrento Temperature Wrong  (Read 2874 times)
pebbleridge
« on: July 25, 2021, 11:03:01 am »
Hi Guys,
I'm new to the forum, having "adopted" a 2004 Hot Spring Sorrento (it was installed in our home by the previous owner).
We have a problem with the temperature control.
It's much hotter than the settings display.
If we set it at 26 degrees C it controls at about 37 degrees C.
It's not a big problem, because it does control, but we would feel happier if it controlled to the temperature it was set at.
Has anyone else had this problem?
Paul
cranbiz
Re: Hot Sprint Sorrento Temperature Wrong
« Reply #1 on: July 27, 2021, 09:40:52 am »
Sounds like the temp probe is bad.
pebbleridge
« Reply #2 on: August 04, 2021, 04:22:29 am »
Do you think it's possible to change the probe.?
cranbiz
« Reply #3 on: August 04, 2021, 08:10:24 am »
Yes, it's possible, done all the time. Post up a picture of the inside of the spa pack, the wiring diagram on the cover and of the equipment area so we can see exactly what you have.
