Author Topic: Caldera Spa popping/crackle noises  (Read 2412 times)
dpeters
« on: July 04, 2021, 12:19:54 pm »
Have a 2018 Caldera tahitian with sound system and subwoofer.  About 2-3 months ago started getting awful popping or crackling noises from the subwoofer.  Would start with just a few pops, then at times would continue for a hour.  All times of the day/night.  We did have a handrail installed screwed into the frame of the spa.  And seems to have started after this was done.  Have had spa techs out 3 times and can not find what is causing the noises.
This past week have removed the handrail and now we are just hearing a single or double popping noise roughly every 10 minutes. The constant noise has stopped with handrail off.
I do have audio of the sounds    Also do see there was a leak over one of the pumps caused rust buildup , and also the bottom of the heater looks rusty
Has anyone ever had this issue?
Re: Caldera Spa popping/crackle noises
« Reply #1 on: July 04, 2021, 04:03:12 pm »
Is the music system on or off when you are in tub?
dpeters
« Reply #2 on: July 04, 2021, 04:05:46 pm »
The ‘noises’ occur when we are not in hot tub.  Can be in the house. And hear it
dpeters
« Reply #3 on: July 04, 2021, 04:19:52 pm »
Here is a 30 second video with the noises   With the handrail on
https://youtu.be/7hY_93ZK63U
CanadianSpaTech
« Reply #4 on: July 04, 2021, 06:47:03 pm »
Is there an on/off switch inside the stereo enclosure? most subs will have a volume control built in that can be turned down a bit. https://manualzz.com/doc/29173345/stb-bluetooth-subwoofer-pairing-instructions
WITH NO MUSIC OR SOUNDS PLAYING, SYSTEM MAY       EXHIBIT LOW LEVEL BACKGROUND NOISE DUE TO        BT SEARCH FUNCTION.   TURN THE POWER SWITCH       “OFF” WHEN NOT IN USE.
dpeters
« Reply #5 on: July 05, 2021, 06:08:35 pm »
There is a Bluetooth on/off on the display and yes it is off.
