Author Topic: Clear gel forming around filter inlet?  (Read 3151 times)
xMeta4x
« on: June 28, 2021, 01:20:24 pm »
Hi Everyone.
I just drained my tub, refilled, and balanced everything out like normal.
I make a habit of running my fingers around the filter inlet grill at the bottom of the tub to remove any large debris that gets trapped there.
Today I found a layer of what appeared to be completely clear gel on there! I was able to remove some of it, and it came off like a sheet. The rest seemed to get mushed up by me running my fingers over it and went through the grill, so is probably in the filter.
What on earth is it?! It was like jelly almost in texture and appearance.
cranbiz
Re: Clear gel forming around filter inlet?
« Reply #1 on: June 28, 2021, 01:28:06 pm »
Sounds like Biofilm.
Have you done an Ahh-some purge?
CanadianSpaTech
« Reply #2 on: June 28, 2021, 04:23:08 pm »
x2 Ahh-Some
xMeta4x
« Reply #3 on: June 29, 2021, 09:19:05 am »
Thanks for the replies, I haven't flushed the tub at all. Is it likely to be biofilm if it's totally clear?
I thought it would at least have been milky coloured or something.
