Author Topic: Two (2) speed pump - issues  (Read 1747 times)
dus
« on: May 30, 2021, 05:37:23 pm »
Just replaced my spa pack with a BP7 (replacing a BP500) because of heating issues last fall.
For some reason, my main 2 speed pump doesn't turn on low speed (only high speed).  Terrible for heating situations as high speed auto shuts off (plus I wouldn't want to be running on high all the time anyway).
I switched the wires at the pump to test low speed availability and it does indeed work.
This is a brand new pack, why would I have issues with the signal on the low side?  I can hear the "clicking" sound when it's the pack is trying to turn on the low speed but with no result.
Any help is appreciated!
cranbiz
Re: Two (2) speed pump - issues
« Reply #1 on: June 01, 2021, 11:47:23 am »
Can you post up a picture of your spa pack and the wiring diagram on the inside of the cover?
I wonder if you need to change a dip switch.
CanadianSpaTech
« Reply #2 on: June 01, 2021, 03:56:26 pm »
Check for a loose blk wire...lol
