Author Topic: Freshwater Salt Cartridge Lifespan Experiences  (Read 25781 times)
Olivia23
Re: Freshwater Salt Cartridge Lifespan Experiences
« Reply #15 on: April 26, 2021, 02:54:22 pm »
That's good to hear. I'm getting ready to put a down payment on a Hot Springs Envoy and I've been debating about taking off the Freshwater system because of all the issues people are having. I really want the saltwater system since everyone says it feels so much better on your skin but I wonder if it's worth the headache and the cost.
« Reply #16 on: April 26, 2021, 04:23:21 pm »
This is where good dealers come shine. Its interesting how it seems phosphates are key to getting this to work properly but a good dealer should be setting up the customer to win on water care no matter the system being used. Discuss all of this with your dealer in detail and see if it seems like they'll be a good guide, sometimes its not the salesperson but someone else at teh dealer who knows this area best (hopefully its everyone there but not always).
Its great to get info here but the dealer should be directing you from the moment the spa is delivered (or even beforehand really) rather than you learning here after you've been struggling in your back yard. When products are new dealers have to learn as well but its not like this was unveiled last month. We all say how important the dealer is in the customer satisfaction area and this is an example.
jzellers
« Reply #17 on: May 11, 2021, 11:05:44 am »
Yeah, my spa is about the same age as yours.  I have drained once and it didn't affect the cartridge lifespan.  I have also tried lower output settings and that didn't seem to work either.  If the issue persists I will have to make the dealer test for phosphates.
Got my water tested and phosphates came back at 3000.  I was told 125 is where I need to be.  Everything else was balanced well.  Going to get some phosphate remover from the dealer and update on progress as I go.
Hi, I am having similar issues, 5th cartridge in 8 months.  I am curious if you are on well water or city/municipal?  My technician has mentioned Phosphates before but has never tested.  I assumed that municipal water would not have such an issue but i could be wrong.
Also curious if the phosphate remover worked.
Is your spa fairly new? I received my spa about 7 months ago in September. I went through 5 cartridges by January. I drained my spa around January 9th, and started fresh with new water and a new cartridge. I added about 3 oz of phosphate remover per dealer testing instructions and almost 4 months later I'm still on the same cartridge. In fact my cartridge has outlasted my water as I just changed it again yesterday and am still using my cartridge from January.
My dealer said all their customers were struggling with the cartridges since last fall. But they also acknowledged they weren't treating phosphates much. They tested but didn't necessarily treat it. I think its a combination of bad cartridges and phosphates issues.
It will be telling when my current cartridge goes out. I still have 3 that I purchased from last fall. My current cartridge came from a different cartridge order back in January. When its time to put a new cartridge in if the new cartridge doesn't last very long I'll for sure that the batch was bad.
mgulya
« Reply #18 on: September 10, 2021, 02:38:36 pm »
So I have a Caldera spa that just hit 1 year in July, and I too have the Freshwater Salt system cartridge.
Here is what I have learned to make my life easier:
1. I ordered Phosphate test strips https://www.amazon.com/gp/product/B00MGKF32C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2. Phosphate remover: https://www.amazon.com/gp/product/B00PZZFQRM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
3. when ever i get 1 0 reading of chlorine in my tub i test for phosphates and depending on the reading seems like once i hit 300 i lose chlorine, 1st I add 1 cup of liquid shock followed by the phosphate remover. 24 hrs later i retest and see where i am at. this keeps my water good for about 10 months.
cartridge issues i had 1 work for the 4 months and reach when the display said time to change it out.
every other cartridge somewhere in the 2-3 months will say low output levels. once i put a new one in everything works. My dealer says it is a chemical balance issue but i just got all my levels perfect and it still says low output.
has anyone figured out how to get 3-4 months with these cells. mine are all black with a grey little button and gray tabs on the side.
wcmorris
« Reply #19 on: September 15, 2021, 08:39:17 am »
I've had my new Envoy for a little over a month now and have been struggling to get the salt system to work properly. I initially had an issue with alkalinity and pH being high and it took weeks before I could get it balanced. During that time, the salt system always showed 'okay' with the arrow hovering in the left yellow and sometimes hitting perfect. I had my best stretch with the salt system after I took a water sample to my dealer and they said I needed to lower the phosphates. Once I did this, it seemed to run pretty well for a week or two. However, I have also noticed it's had trouble maintaining chlorine on it's own. I've been adding non-chlorine shock twice a week to help it maintain and I've been boosting the salt cartridge and leaving it between 8 and 10 output just to keep the chlorine levels within range. Yesterday, the green light started blinking and it looks like now my salt cartridge is dead after 1 month.
I'll say that when the system works it is nice. The water feels soft and doesn't dry out my skin like a typical hot tub. But so far is been a headache to maintain and now my cell is dead 3 months premature. I think I'll give it once more shot now that I understand the system a little more maybe I'll have better luck. If it still struggle then I'll probably abandon it and look at the @ease system instead.
Any suggestions on how to have better luck with the salt system is appreciated. For instance, should I be shocking the tub twice a week? When do I boost instead of shock? What would you expect the output level should be set to for two people using the tub for 30 minutes a day?
Sammi
« Reply #20 on: September 15, 2021, 08:32:07 pm »
Put Ah-Some or another similar product in and drain it.  Then start over with fresh water, balance alkalinity and ph, and use Spa Guard Chlorine Enhanced Spa Shock once or twice a week depending on usage. I put some in after about every 3rd or 4th spa usage and keep my output on 6. The system has worked great since my first drain and refill using the above method. Oh yeah - also have your water tested for phosphates.
wcmorris
« Reply #21 on: September 16, 2021, 10:51:49 am »
Thanks for the input. Sounds like you had the same issues I've been dealing with so glad to hear you got it figured out. I'll follow the same method and see if I have any luck.
swaney
« Reply #22 on: September 17, 2021, 09:19:38 pm »
Galaxy
 How many gallons is your spa?
Galaxybrooks
« Reply #23 on: September 26, 2021, 09:23:57 pm »
I believe it's 375.
Update since my flush, drain, and refill first week of June.
I'm still on the same salt cartridge heading into the end of 4 months next week.  I'm going to say a drain and refill with proper balance to begin with makes all the difference.  Considering the summer has been hot and we have been traveling the tub spent a lot of time in vacation mode but even so the tub has been pretty good at sanitizing with a 4 to 5 setting when in use.  In fact most of the time it's been at at 3 or 4.  Weather here in NC has been starting to get back into the upper 50's at night so we have been using the hotub a lot the last week so I've had to use Oxidizer and the boost function to keep up with the demand.  Being I'm close to 4 months on the mineral stick and cartridge that may be part of the need for turning up the salt settings.  Salt has been at a perfect 1750 for the most part.
Final thoughts I think the drain and refill helped but given the summer months contributed to little use I'm going to have to see how things go moving forward in the cooler months as we frequent the warm bath waters of Caldera in the ole backyardo.
My dealer had been as helpful as possible and stand behind that most people don't have much trouble with the system and their now recommending a drain and refill If things aren't working as expected.
JohnMillard
« Reply #24 on: February 23, 2022, 11:42:31 am »
Having same problem.  Every ~ 45 days, like clockwork, the salt cartridge fails.  The've been out five times and are trying one more thing tomorrow, but they say if that doesn't fix it then I'm relegated to replacing for the lifetime of the tub every 45 days and they will credit the short life of each cartridge.  Not happy with this response after spending almost $20,000
jonat
« Reply #25 on: March 01, 2022, 03:35:51 pm »
I received the following from my dealer today:
"Greetings from the Mainely Tubs Service Team,
We are reaching out to you today, not only as a valued customer but also as a salt system hot tub user.
We wish to update you with some very important changes to the salt system water care procedures. We have seen an increase in foaming and shortened life spans of customer ACE® cells and FreshWater® salt cartridges. Normal explanations and corrections have not been as effective as we would like to see, which prompted Mainely Tubs to do some research and testing. Our findings have revealed that the cause, in most cases, is related to high levels of phosphates in the water.
Phosphates are not harmful and are naturally occurring compounds in our lives that are found in our food, water, and bodies. They are introduced to our water with detergents, lotions, rain and snow runoff, dirt and soil, animal droppings, lawn and garden products, etc. We have discovered phosphates in both well and city water supplies.
Due to these findings, we are now recommending that our salt water customers test for phosphates.
If Mainely Tubs or you should discover a phosphate issue, there will be an added step to your water care treatment. It requires an additional test and if positive will require that you add the appropriate amount of Natural Chemistry® Phosfree® phosphate remover, which is a product that Mainely Tubs now stocks and sells, including the appropriate Natural Chemistry® Phosphate test strips. While this is an added step and expense, we feel strongly that once this becomes part of your normal tub maintenance, if needed, you will experience better water quality and a more enjoyable hot tub experience."
(The test strips and remover are cheaper on Amazon.)
Sammi
« Reply #26 on: March 01, 2022, 10:45:48 pm »
Have they tested for phosphates? As previously noted my tub has worked great getting 4-6 months out of my sticks now (had the same issues as you the first 3 months). Stagnant water on first start up and high phosphates are the two culprits I've discovered. Phosphate remover is cheap, and really only needs to be used at initial fill.
jonat
« Reply #27 on: March 03, 2022, 02:58:31 pm »
Just tested my new spa for phosphates - wow! a 1000 reading. PhosFree coming tomorrow.
LRing1961
« Reply #28 on: May 05, 2022, 12:51:41 pm »
I have a 2019 Limelight Flash. I've had it two years and kept perfect records on each cartridge change. For me it's every 6 weeks. All have been grey button (i'm pretty sure - certainly all of the last batch were). I keep it at 7, per dealer recommendation. I tried it at 3 and 4 for a while, but we use it every day, 20-30 minutes per day, and it wasn't keeping up.
Is this normal? It feels like A LOT of cartridges, which are not cheap, by the way.
cranbiz
« Reply #29 on: May 06, 2022, 09:20:40 am »
Are you testing for Phosphates? If not, start testing. The phosphate level should be 300ppm or less for optimum salt cartridge life.
