Author Topic: Ahh-some procedure?  (Read 2120 times)
amorak
Ahh-some procedure?
« on: January 06, 2021, 09:02:28 pm »
Hi all,
Bought a new strong spas hot tub through costco canada in the summer.  Having an issue with 'dirty bubbles' when we turn the blower on, regardless of fresh water flushes.  Thinking of getting some ahh-some and running a purge or three.
Wondering, once the ahh-some has run for 30 minute sand created a lot of suds and crud, how do you get rid of it? turn off the blowers and then wipe off the crud before it hardens? and then pump out the tub, refill and repeat?
Ahh-some procedure?
CanadianSpaTech
Re: Ahh-some procedure?
« Reply #1 on: January 07, 2021, 09:26:36 am »
Remove the filters, Turn off the air injector valves and the blower as well. Run it for 30 mins then drain and clean wiping down the side walls as it drains. Sounds to me like there is a need for a better weekly chemical process. How often are you cleaning your filters? Do you use spa shock? Where in Canada are you located?
