Welcome to our forum.
Hello Sammi Any updates on your Envoy? Maintenance, lighting, etc.? Thank You
Buy cheap paper filters from amazon?? Can you elaborate on that more
Kind of an old post but lets see if we can resurrect. Sammi, I'm curious how the Envoy is a year on. I just got mine last month and we've been loving it other than having issues dialing in the salt system. You mentioned adding chlorine once a week and having the system set to 10. The manual says you shouldn't add chlorine once the system is maintaining 3-5 ppm on it's own. We're you ever able to get it dialed in so you only have to use non-chlorine shock once in a while and set the output lower to like 6 or 7? How long are the salt cartridges lasting you?I've been having a similar experience as you where I have it set to 10 and have been boosting constantly but I still find it struggles to maintain. I now just got the error where it looks like the salt cartridge needs to be replaced. My dealer charges $250 for a three pack which I refuse to play if I'm replacing them every 1 to 2 months.
Thanks for the updated. I cleaned my filters yesterday and tried to reset the salt system as the manual suggests that dirty filter can be one cause of the salt system failing. It almost immediately turned off again so I assume now that the cartridge needs to be replaced. My plan now is to do a drain and refill as you and others seemed to have good luck with this. I order ahhsome, salt cartridges, and vanishing act pillow. I'll give it a go this weekend and see what happens. Do you try to fully balance water before activating salt system? If my second fill is anything like my first, it took weeks of adding pH down once a day before pH and Alkalinity balanced. My calcium was between 0 - 25 the entire time and has stayed steady. My dealer said salt system could be activated before all the other levels were perfect but I'm not sure I buy that.
