Author Topic: Hot tub base  (Read 2117 times)
Bg
Hot tub base
« on: September 03, 2020, 10:03:36 pm »
I am new to the hot tub game and trying to figure out what base to make for it. I have a huge concrete patio. The issue is that it is sloping away from the house and is not level. I really like the frame idea with gravel inside but can that be done on top of a concrete slab that isn’t level if I rip the frame to make it level and then also level with the gravel?
It’s either this or I build a small deck that bolts to the slab and wood is ripped the make it level.
Any input would be greatly appreciated!
Thank you
Hot tub base
Re: Hot tub base
« Reply #1 on: September 04, 2020, 10:58:49 am »
Thank you
How un-level is it over 8'?
CanadianSpaTech
Re: Hot tub base
« Reply #2 on: September 05, 2020, 09:42:52 am »
Rigid foam. 1/4", 1/2", 3/4". level spa up on block to the correct height and slide in the foam starting small up to needed height for level. Cut/trim foam to match base and then you could trim the bottom with wood if you don't like the pink showing.
Re: Hot tub base
