Author Topic: Balboa TP500 - what setting do you have your hot tub on?  (Read 1946 times)
Jodes112
« on: August 23, 2020, 08:23:43 am »
Hi,
We got our hot tub and filled it up. Heating lovely ect.
However, manual doesnt make much sense to us, with regard to filter cycles ect. And we are unsure what settings to use for the usage it gets.
We are using the tub daily in the evenings (we are in uk so weather is cool) What would you recommend the settings be on with regard to heat/filtration ect. We are concerned it isnt entering a filter cycle enough, howere arent sure what is too little and too much. Confused much. Any advice would be great.
Re: Balboa TP500 - what setting do you have your hot tub on?
« Reply #1 on: August 23, 2020, 04:53:30 pm »
Most tubs with "normal" usage need about 4 hours a day. Heavy use maybe more. You are still using it a lot so maybe more. What are you using for sanitation? I'm assuming no small 24/7 circulation pump?
