Author Topic: Flo code  (Read 2537 times)
chrisonowasco
Flo code
« on: July 13, 2020, 04:03:53 pm »
I have an older what i believe is a Reflections?Vita hot tub. I keep getting a FLO error code. I made sure there was no air in the lines, I then looked for a pressure switch, apparently there isnt one on this type of spa. Any ideas or advice?
Flo code
CanadianSpaTech
Re: Flo code
« Reply #1 on: July 13, 2020, 06:11:32 pm »
Dirty Filters? Remove filters until issue is fixed
chrisonowasco
Re: Flo code
« Reply #2 on: July 13, 2020, 06:14:01 pm »
Thank you for the reply. I tired that already. There’s no pressure switch on the heater. Not sure if I should just replace that next? Any help is appreciated.
CanadianSpaTech
Re: Flo code
« Reply #3 on: July 14, 2020, 04:31:43 pm »
Well it's a flow issue so it shouldn't be the heater
chrisonowasco
Re: Flo code
« Reply #4 on: July 14, 2020, 04:40:05 pm »
Possible air lock?  Maybe I should drain the tub and refill it?
JayTee
Re: Flo code
« Reply #5 on: July 16, 2020, 04:59:44 pm »
I had a very persistent air lock until I drained, then filled my tub Via the inlet for the heater circulation pump. That being said i purchased the wrong pump and its about %50 the strength thats meant to be in there, but after filling from the inlet she started working just fine.
https://www.youtube.com/watch?v=cQeVKaTnwOw&t=79s
skip to 1:40
Re: Flo code
