Author Topic: Foam  (Read 2264 times)
TonyInTennessee
Foam
« on: July 10, 2020, 09:30:23 am »
New to the hot tub world...I've searched this forum and I'm not seeing the question already answered. We've had our new hot tub for just over a week now. We've followed the dealers advice on start up chemicals but we are finding ourselves with a tub full of foam or suds whenever the pumps are running. We have made sure that we only wear swimsuits that have been washed in water without soap. We are taking a water sample in tomorrow to be tested but I wanted to see if anyone had any ideas.
Foam
castletonia
Re: Foam
« Reply #1 on: July 10, 2020, 10:07:13 am »
Was the foam present prior to you using the hot tub or did it not appear until after first use?
TonyInTennessee
Re: Foam
« Reply #2 on: July 10, 2020, 02:52:17 pm »
We used the tub the same day that it was installed. The foam appeared after using it.
swilly1000
Re: Foam
« Reply #3 on: July 11, 2020, 07:47:40 am »
Are you sure there was no residual soap in the swim suits from earlier washes?  Sounds like the suit are the problem.
TonyInTennessee
Re: Foam
« Reply #4 on: July 11, 2020, 09:50:32 am »
It's quite possible.
CanadianSpaTech
Re: Foam
« Reply #5 on: July 11, 2020, 11:26:42 am »
New spas are tested at the factory often using the same water over and over also it's new and will have some remnants from manufacturing process. Use spa shock and clean filters regularly
TonyInTennessee
Re: Foam
« Reply #6 on: July 11, 2020, 10:56:57 pm »
After having my water tested at the dealer, it ends up that my Ph was extremely high...which is also a cause for foam. According to the dealer, the high end of the normal range is 120, mine was 364!
Re: Foam
« Reply #7 on: July 12, 2020, 06:51:40 am »
That's Alkalinity
Re: Foam
