Author Topic: above ground pool foundation thermo barrier sheets & adhesive  (Read 2037 times)
jgy2001
Getting above ground pool. Built concrete slab already.
What kind of thermos vapor insulating floor barrier sheet do you recommend?
What kind of adhesive do you recommend? Should we get hardwood flooring adhesive? Urethane flooring adhesive?
Thank you.
jgy2001
Re: above ground pool foundation thermo barrier sheets & adhesive
« Reply #2 on: July 13, 2020, 02:45:44 pm »
We are thinking of these, what would you choose?
1. https://www.amazon.com/gp/product/B01050H8MM/ref=ox_sc_act_title_3?smid=A226NGGGPAUWSH&psc=1            100sqft (2ft Wide) of NASA TECH Commercial Grade Solid White Non Perforated Platinum No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD
2.  https://www.amazon.com/gp/product/B000BPAULS/ref=ox_sc_act_title_2?smid=A2Q1LRYTXHYQ2K&psc=1                Reflectix BP48010 Double Pack Insulation, 48 in. x 10 ft
3.   https://www.amazon.com/gp/product/B0104ZUNDO/ref=ox_sc_act_title_4?smid=A917DJU8KFW86&psc=1                 250sqft (4ft Wide) of NASA TECH Commercial Grade Solid Platinum Non Perforated No Tear Green Energy Radiant Barrier Reflective Insulation Solar Attic Foil Roof Attic House Wrap SCIF RIFD
4.   https://www.homedepot.com/p/Roberts-120-sq-ft-10-ft-x-12-ft-x-0-006-in-Roll-of-6-mil-Moisture-Barricade-Polyethylene-Underlay-Film-70-115/100578718        120 sq. ft. 10 ft. x 12 ft. x 0.006 in. Roll of 6 mil Moisture Barricade Polyethylene Underlay Film
5.  https://www.homedepot.com/p/Roberts-AirGuard-100-sq-ft-40-in-x-30-ft-x-2-mm-5-in-1-Underlayment-with-Microban-for-Laminate-and-Engineered-Wood-Floors-70-105/202299502      AirGuard 100 sq. ft. 40 in. x 30 ft. x 2 mm 5-in-1 Underlayment with Microban for Laminate and Engineered Wood Floors
