Author Topic: marin32 no heat or pump  (Read 2546 times)
RORER7114
« on: May 21, 2020, 11:31:49 am »
hi please help really miss my hot tub i have a 1994 marin32 with a problem when i turn it on i have no heater light also jets dont work what does work are the light and the blower motor when i press the jet button i hear a buzzing i think it the rellay could it be the heater rellays please help stuck
Re: marin32 no heat or pump
« Reply #1 on: May 21, 2020, 01:12:38 pm »
If your pump fails your heater won't work.
RORER7114
« Reply #2 on: May 23, 2020, 04:24:19 am »
Can you please tell me how to check the pump i am sorry new to all this
« Reply #3 on: May 23, 2020, 07:44:43 am »
My first move is to hook up a functioning pump of the same aprox. size, This tells me if the pump has had a failure, then I take the old pump and put it on the bench for testing.
I say call a repair guy unless you just want to assume and replace parts.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #4 on: May 23, 2020, 09:14:43 am »
Do you know how to use a volt meter?
RORER7114
« Reply #5 on: May 23, 2020, 01:58:22 pm »
yes
« Reply #6 on: May 23, 2020, 02:45:38 pm »
yes
See if you have the proper voltage at the pump leads. This will tell you if the relay is sending power to the pump.
RORER7114
« Reply #7 on: May 23, 2020, 06:58:25 pm »
ok i will try that thank you
