Author Topic: PUMP WONT STAY ON  (Read 3669 times)
RORER7114
PUMP WONT STAY ON
« on: March 18, 2020, 07:30:29 pm »
Hi I have a sundance spa marin 32 1992 I have run into a problem the spa pump wont stay on changed all the fuses turns on for about 2 seconds then turns off please help also the circulation pump is not working the heater light are not on as well thanks
PUMP WONT STAY ON
Re: PUMP WONT STAY ON
« Reply #1 on: March 19, 2020, 08:16:30 am »
If the circ pump isn't working the heater won't work, they only work in conjunction. The jet pump is a different problem. Start with circ pump, how old is the pump?
CanadianSpaTech
« Reply #2 on: March 19, 2020, 09:32:29 am »
1992...WOW
RORER7114
« Reply #3 on: March 20, 2020, 02:16:55 am »
the pump is about five years old
« Reply #4 on: March 20, 2020, 08:21:02 am »
That seems like a bit of a short life span for a circulation pump, has the tub been wet and turned on for all of those 5 years until recently?
RORER7114
« Reply #5 on: March 20, 2020, 11:05:39 am »
yes
« Reply #6 on: March 20, 2020, 02:30:23 pm »
Filter clean and regularly replaced?
RORER7114
« Reply #7 on: March 20, 2020, 07:28:36 pm »
yes
« Reply #8 on: March 20, 2020, 07:39:15 pm »
yes
Well maybe your board is bad. But a tech may carry a replacement circ pump to test the system board. Unplug the circ pump and heater and see if the jet pump works.
Do you know how to properly power down your tub?
RORER7114
« Reply #9 on: March 21, 2020, 03:12:25 am »
ok I will try that in the morning thank you
RORER7114
« Reply #10 on: March 21, 2020, 03:14:51 am »
not sure how to properly shut it down
« Reply #11 on: March 21, 2020, 08:16:28 am »
At the breaker.
CanadianSpaTech
« Reply #12 on: March 21, 2020, 10:01:34 am »
If this is the case call for service
RORER7114
« Reply #13 on: March 21, 2020, 02:29:59 pm »
I know how to do it at the breaker I just thought you had some sort of special way to shut down
