Author Topic: Treatment of Spa Cabinet  (Read 4978 times)
Max78
« on: September 21, 2004, 02:59:29 pm »
I've applied 303 to my cover (is this a good idea?  Some say yes, some say no) and was wondering if there is anything I need to apply to my synthetic cabinet for protection?
huh?
  • "42"
Re: Treatment of Spa Cabinet
« Reply #1 on: September 21, 2004, 04:26:14 pm »
What kind of tub/synthetic cabinet do you have?
Max78
« Reply #2 on: September 21, 2004, 06:52:06 pm »
Optima with the Sierra synthetic cabinet
huh?
  • "42"
« Reply #3 on: September 21, 2004, 06:54:45 pm »
You shouldn't really have to put anything on it.  One of the best features for a synthetic cabinet is the lack of maintanence needed.  If it is dirty you can just hose it off.  If you want to go a little further, try some 303.  But you shouldn't need to.  You might try asking your dealer if there are specifics to the warranty, however.
Good luck!
Cheers
KC-SWO
  • Waiting for my new deck, Dreaming of my BC 750
« Reply #4 on: September 22, 2004, 02:19:45 pm »
How often should a cedar cabinet be treated?
keesterdog
« Reply #5 on: September 22, 2004, 02:59:18 pm »
kc
it really depends on what it is initially treated with.  if it's someting Thompsons water seal you may need to do it yearly.  personally, after researching and on the advice of my tub manufacturer, I used the Sikkens brand. one coat of the cetol 1 and 2 coats of the cetol 23. That was 2 years ago. with a rinse off the sides still look brand new.  however,  the top rail which on my tub, has exposed wood, could use a new coating this year.  another factor is how much direct sunlight your tub receives.  the more direct sun the more frequently you will need to treat it.
« Reply #6 on: September 22, 2004, 06:23:56 pm »
I treat my cabinet with superdeck transparent stain yearly.
rocket
  • Life is good!
« Reply #7 on: September 22, 2004, 06:53:01 pm »
KC,
Good advice from keesterdog, I would add that it depends upon the type of wood.  Too many manufacturers are using a less quality wood and I believe that it will take more maintenance to keep the wood lasting a long time to gain the value from the spa.
My guess is that the manf. will recommend restaining every 6 months.
