Author Topic: Marquis Spa is Screwed...literally  (Read 4002 times)
CanadianSpaTech
« on: February 07, 2020, 11:26:53 am »
https://photos.google.com/album/AF1QipMDzdYvspyzFDNTWtL0fNNWImbR3fNdzUQrmKlB
Interested in hearing how others would approach this repair. It is a 2003 Marquis Spa "Escape". It was a removal/dump tub and I normally this time of year (-10C and no indoor working space) I would just strip it for parts and dump it but the spa was retro fitted with a 2014 Balboa pack and topside and the pumps look to be updated as well. Other than the screw poking through it's not bad shape and I have $0 dollars invested.
Re: Marquis Spa is Screwed...literally
« Reply #1 on: February 07, 2020, 03:15:38 pm »
I'd love to help but the photo link is no good.
BullFrogSpasMN
« Reply #2 on: February 07, 2020, 05:27:07 pm »
bad link...I assume a screw hole through the shell? if so I'd probably order a fairly standard acrylic repair kit that comes with the 'sand-able' compound...hell if you want you could order the colored kit and come up with a pretty close match to the existing shell color.
« Reply #3 on: February 07, 2020, 07:00:20 pm »
If it's only a screw hole even silicon could work depending on the location.
CanadianSpaTech
« Reply #4 on: February 07, 2020, 07:14:29 pm »
« Reply #5 on: February 08, 2020, 08:07:28 am »
Sorry. How about now... https://photos.app.goo.gl/Zps73riYdqB7tVuA9
If its a decent tub I think I would use a fiberglass repair kit or epoxy repair kit. A bolt and nut with rubber washer and silicon sealant There are tons of ways to fix it.
CanadianSpaTech
« Reply #6 on: February 08, 2020, 11:16:19 am »
Thanks for the reply. Were you able to open the photos using the second link?
Super cold here but should warm up a bit by Monday. Will have to get out there and open it up for a closer look on the inside. I have done a handfull of glass backed Lucite Acrylic repairs in the past but nothing in the last 8-10 years. Anybody know what the shell and backing matreials are made up of on one of these Marquis?
« Reply #7 on: February 11, 2020, 08:33:53 am »
They are fiberglass backed acrylic.
Yes the link worked.
CanadianSpaTech
« Reply #8 on: February 11, 2020, 09:42:22 am »
THX Tman... Warmed up yesterday enough to get a closer look. Found a couple of other issues one being a large bubble almost the size of a baseball that once I touched it it oozed rust and flaked right off so I decided to just strip out the pumps, pack and topside and junk the rest. Thanks for the input. On to the next one.
« Reply #9 on: February 12, 2020, 08:38:43 am »
Chainsaw
