Author Topic: Umbrella with side tilt capabilities  (Read 2785 times)
outdoorfan
« on: February 04, 2020, 07:14:01 pm »
I've got a rather unique shade need for my spa.  The location of the spa is covered with trees on 3 sides and above.  The open-to-the-sky side is just right for the 3pm-to-sunset sun to cut like a knife at a 45 degree angle right into the spa, making that coveted early evening time unpleasant to just lounge in the spa.  That open side happens to be entry side of the spa as well.
Most spa umbrellas have a single directional "tilt" on the plane of the cantilever pole itself like https://www.leisureconcepts.com/products/spa-accessories/spaumbrella.  That movement lets you move the shade from the top to the side where the umbrella base is mounted or placed.
I obviously can't place the umbrella base (or mount) where the stairs to enter the spa is, so what I really need is an umbrella that has a side tilt option which would allow me to mount (or place) the umbrella on one of the sides of the spa and then tilt the umbrella on it's side so that it can block the sun cutting in on the entry side.  Similar to this one - https://authenteak.com/treasure-garden-13-akz-plus-octagonal-cantilever (Pic #3 in the listing shows the movement I need).  The problem with that one is that it's $1200 and it uses a base where I'd prefer to have something anchored under the spa like most spa umbrellas.
Has anyone seen, used, bought a side tilting spa umbrella as described?  Ideally one that's not $1200?
« Last Edit: February 07, 2020, 01:14:25 pm by outdoorfan »
Re: Umbrella with side tilt capabilities
« Reply #1 on: February 04, 2020, 08:12:00 pm »
https://www.homedepot.com/b/Outdoors-Patio-Furniture-Patio-Umbrellas-Cantilever-Umbrellas/With-Stand/N-5yc1vZcfiaZ1z18wt0
Cantilever style patio umbrella?
I have one and while it doesn't tilt it swings all the way around, open and close slightly more or less to adjust the height of the shade.......
