Author Topic: Pump not turning on automatically  (Read 3633 times)
Scottystepp
« on: January 17, 2020, 11:55:11 am »
I have an older Marquis spa. Everything works normally except that the pump won't turn on to cycle/heat automatically. If I start the pump by pushing the control panel button it will heat the tub up to temp and then shuts down but won't turn back on automatically. All jets work and have a new filter installed. Any ideas?
Re: Pump not turning on automatically
« Reply #1 on: January 17, 2020, 02:22:34 pm »
Is the tub in standby mode or economy mode?
Scottystepp
« Reply #2 on: January 17, 2020, 10:06:58 pm »
It's 20 years old so I don't think it has that option but I'm honestly not sure. How can I check? Thanks.
« Reply #3 on: January 17, 2020, 11:22:31 pm »
Depending on model and year if you know both you can download the manual on Marquis website. If you don’t know post a picture of controller here
Scottystepp
« Reply #4 on: January 19, 2020, 01:01:36 pm »
Sorry, I can't figure out how to post an image.
It is a Marquis Recreational Series- Quest model (1999).  The controller has 3 buttons. 1. On/Off (light); 2. Low/High Therapy (jets); 3. Temp/Filter.
Here is the manual link:
https://www.marquisspas.com/documents/older_manuals/1999/MS%20Leisure%20Recreational%20Coastal%20MTS%201999.pdf
Control panel can be seen in the top left corner of pg.22.
Many Thanks!!!
